Author Topic: Connectors for Breadboard and PCB: GPS module EM-506  (Read 277 times)
Offline GerelectronicTopic starter
« on: April 25, 2024, 11:24:17 am »
Hi everyone.
I'm trying to create a project with an EM-506 GPS Module.
The problem is that I can't understand what types of connector I should use to test the GPS module (which already has a cable with a female connector) on:
.- Breadboard,
- And subsequently also on PCB;
Sorry if it's a trivial question, but even searching on the internet I'm not sure which connectors are suitable.
I also tried to consult the datasheet, but unfortunately I can't find the information I need.
Additionally, where do you recommend I buy them?
I'll add two photos so maybe you can understand better.
Thanks a lot to everyone.
Offline xvr
  • Country: ie
    • LinkedIn
Re: Connectors for Breadboard and PCB: GPS module EM-506
« Reply #1 on: April 25, 2024, 11:54:19 am »
Looks like JST SH 6 pin series. Take a look for EM-506 sellers, they also often sell a cable with JST socket.
Example: https://www.sparkfun.com/products/9123
The following users thanked this post: Gerelectronic
Offline Solder_Junkie
« Reply #2 on: April 27, 2024, 07:59:43 am »
 You can buy kits of those type of connectors from eBay and Amazon, measure the pin spacing to make sure they are the same. Crimping tiny connectors is challenging though, I have damaged quite a few pins when crimping and now use a mixture of solder and crimp tool...
In my GPSDO projects, I have used GPS boards which include a micro USB socket. It makes testing/configuring much easier.
SJ
Online Ian.M
« Reply #3 on: April 27, 2024, 08:17:55 am »
Does the GPS end of that cable unplug?
If so, either get a cable to fit and mod it with duPont pins to suit breadboarding, or get something like this: https://www.sparkfun.com/products/18081
If not, you need the matching male pin header + one of these: http://www.proto-advantage.com/store/product_info.php?products_id=3800003 and a six pin strip of 0.1" SIL pin headers.
« Reply #4 on: April 29, 2024, 05:57:26 pm »
Thank you all. All your kindly advices are so useful!
