Hello Community..
I am trying to build a bidirectional Flyback Balancer BMS.
At the beginning, i would like to balance 4 Cells… (at the end over 100 Cells, but not directly in a automobile)
So there will be 4 individual Flyback converters…. one for each cell.
I would like to operate the BMS in a Automotive, with LiFePo4 Batteries.
The Batteries are directly charged by the Alternator.
The ECU, Engine etc. is directly connected to the LiFePo4 Batteries (like normal with Lead Acid but there is no LeadAcid Batterie any more).
The 4 flyback primary sides are connected directly (0.5m cable) to each Cell.
The flyback secondary sides are connected directly to the Batterie pack 0V and 14.4V (Bottom Cell1 / Top Cell4)
while discharging: the primary side will switch (4x)10Amps @ 60-100Khz (2.5 - 3.6V (4.5V))
while charging: the secondary side will switch (4x)5Amps@ 60 - 100Khz (10 - 14.4V (18V))
The maximum allowed conducted Emission (in a european automobile) @ 100Khz is around 70dBµA that means
1uA*10^(70db/20db) = 3.16mA.
http://www.fordemc.com/docs/download/FMC1278.pdf (Page 25)
it is just a little Problem to design a Input filter for each Flyback converter, but it is a huge Problem to design a output filter… because it is just toooooo big, and i would need 4 Input Filters and 4 output Filters…
My Question is relatively simple, but i cannot find the answer, and People i have asked… are not willing or not able to answer that question.
My question is.
If i connect the BMS and the flyback converters DIRECTLY (0.5m cable) to the Cells, and the LifePo4 has a typical internal resistant of 1mOhm… (in my case 0.06Ohm?) is it then really necessary to design a filter for 70dBµA?
If it is not necessary because the cell resistant is that small, how much current ripple would be okay?
There are 6Cables
0V
Cell1 +
Cell2 +
Cell3 +
Cell4 +
and the Flyback secondary side is separately connected to Cell 4+
for better understanding attached a simple (experimental) Spice model...
Thanks for any help,
Peter
