Author Topic: Consumer grade enclosure for small/medium quantity product  (Read 2422 times)
Offline AloyseTechTopic starter
« on: February 01, 2019, 01:31:35 pm »
I’m looking for manufacturer that sells of the shelf enclosure with consumer grade design (not plain industrial square box with visible screw etc...).
This this for a wireless desktop product (kind of a network router with wireless), around 100x100x35mm. 1 DC Jack input, 1 RJ45.
I’ve found New Ages Enclosure desktop series (https://www.newageenclosures.com/enclosures/utility--desktop/) but they only have a limited choice when it comes to a given size. There is also OKW Synergy serie, but this is a no go for wireless since they are in extruded aluminium (https://www.okw.com/en/Aluminium-enclosures/Synergy.htm).
Do you guys know other manufacturer of this kind of enclosure?
« Last Edit: February 01, 2019, 01:47:20 pm by AloyseTech »
Online coppercone2
Re: Consumer grade enclosure for small/medium quantity product
« Reply #1 on: February 01, 2019, 01:51:39 pm »
well an option is a extruded enclosure with screwed on metal plates and then snap in plastic cover plates. Or nice decorative screws, if you put a high quality chauffeured torx screw, it does look fairly high quality IMO.
medium quality = go with aluminum +. Plastic would be low quality.
internal antenna: NMV.
« Last Edit: February 01, 2019, 01:54:19 pm by coppercone2 »
Offline ehughes
« Reply #2 on: February 01, 2019, 01:52:31 pm »
https://www.polycase.com
They may a a few things that are close.       They are the best place I have found that will do machining/logos for a reasonable price.
Your next to step is to do low volume injection mold to get the design you want.  protoloabs.com is a fairly inexpensive point of entry.
« Reply #3 on: February 01, 2019, 02:16:19 pm »
Polycase has the XR-46PMBT case (https://www.polycase.com/xr-46p)tha could fit.
The visible is screw is not really an option. I know that nice looking screw do exist (and I personally don't mind having visible screw on a product myself), but it does not fit our target design.
As for low volume injection mold, it might be the only solution for a fully custom enclosure.
Online coppercone2
« Reply #4 on: February 01, 2019, 05:23:47 pm »
If you do extruded al you can also use long standoffs to hold the front cover on and use screw in the back, where the power etc is.
Offline Cloud
  • Country: si
« Reply #5 on: February 01, 2019, 05:39:32 pm »
Check Takachi
Offline SiliconWizard
« Reply #6 on: February 01, 2019, 07:01:58 pm »
Hammond
Takachi
Offline ajb
« Reply #7 on: February 01, 2019, 07:45:34 pm »
In addition to the brands people have already mentioned, there's Pheonix Mecano/Rose Bopla and OKW.  Also Bud Industries, but I don't know if they have anything stylish like you want.  Hammond and Takachi would be my first picks if you want something easy to buy, though.
Offline EmmanuelFaure
« Reply #9 on: February 02, 2019, 12:00:32 am »
Yes but aluminium extrusion is not a solution since I have multiple internal antenna...
I didn't found a well finished case at Hammond. Takachi has the Network serie (http://www.takachi-enclosure.com/data/c16-17/2017vol3_1-10.pdf), I like the separate panel idea (easier to customize), but having a blank pane in the front is not really great I think.
OKW has the EVOTEC serie (https://www.okw.com/en/Evotec/A9441107.htm?var=02efea62-f7ce-11e6-a96b-d219e5f1410f) which is promising, but I heard they are expensive. I will ask for a quotation.
Bud Industries seems to target only plain project box, not any "fancy" design here as far as I've seen.
Offline krho
  • Country: si
« Reply #10 on: February 02, 2019, 01:39:15 pm »
OKW is really really expensive it's 18€+ even in 100pcs for some medium sized enclosuers
Offline Poe
« Reply #11 on: February 07, 2019, 06:15:35 pm »
https://www.clickfoldplastics.com/  is a bit different.
They make enclosures that are good for low volume, low NRE, low cost.
Just another tool in the belt.
