"Hello, I am planning to build a converter using the EGS002 module to convert 350VDC to 230VAC. My question is regarding the inductance of the choke and the type of core to use. It seems that the yellow core commonly used for smoothing computer power supply output voltages may not be suitable. However, the power supply's power factor (PF) choke might be suitable. Also, what should be the maximum output current when using these output transistors(good cooling), to which I will add the load according to the provided diagram?"
https://www.farnell.com/datasheets/3672794.pdf (I don't speak English well and I used chatgpt help.)
