Author Topic: Continuously variable power factor capacitor idea  (Read 329 times)
Offline CirclotronTopic starter
« on: January 21, 2025, 01:59:16 am »
Sometimes you want to find the optimum size power factor correction capacitor to put across a particular load and you end up trying various discreet values until a suitable value is found. Or maybe you need a set of big variable capacitors to excite a stand alone induction generator. What about the following approach? Get a variac and put a suitable  (but relatively small) capacitor permanently across the mains input side so the variac draws essentially zero reactive power. Then connect a relatively large power factor cap across the output of the variac. Connect the variac input to whatever needs an adjustable capacitor.
According to my way of thinking, as the variac is adjusted up and down, the voltage on the output side capacitor varies accordingly, and so it draws an adjustable amount of reactive power. This adjustable amount of reactive power appears at the variac input and so appears as a continuously variable capacitor.
I might have posted this idea some time ago and forgotten about it.
Offline inse
Re: Continuously variable power factor capacitor idea
« Reply #1 on: January 21, 2025, 05:10:00 am »
All theory aside, wouldn’t a DIY capacitor decade box be both more handy and sufficient as well?
« Last Edit: January 21, 2025, 05:30:54 am by inse »
Offline johansen
« Reply #2 on: January 21, 2025, 05:50:56 am »
It works, very few people understand that the change in effective capacitance follows the square of the voltage transformation by the variac.
Its very useful to find the optimal motor run capacitor to maximize efficiency.
The following users thanked this post: Circlotron
Offline coppercone2
« Reply #3 on: January 21, 2025, 08:17:33 am »
Hmm and you can put a DPDT switch on a variac to disconnect the mains and connect it to banana jacks so you can plug it in the lab nicely
or a IEC to banana adapter (for the receptacle, not the cable side)
or outlet to female banana connector
Theoretically safe if there is no suicide cables laying around
« Last Edit: January 21, 2025, 08:21:43 am by coppercone2 »
