Author Topic: control pin state at power up  (Read 2698 times)
Offline ToBeFrankTopic starter
« on: August 03, 2011, 07:29:46 am »
I'm using an Arm Cortex M0 micro. The reset state of all gpio pins is input with pull-up enabled. I need one pin to be low on power up because it is connected to a bus where high is considered to be active on the bus. What can I do to make sure this pin is low at reset? I tried various values of pulldowns (100k down to .5k) and none of them worked.
Offline Bored@Work
Re: control pin state at power up
« Reply #1 on: August 03, 2011, 08:11:17 am »
Measure.
If a 500 Ohm resistor can't pull down the bus it could be
- that you have connected another pin to the bus, i.e. you are messing with the wrong pin
- that something else is pulling the bus up
Therefore measure what is really going on on the bus, e.g. how much current is going through your pull-down resistor.
And if you are willing to risk some magic smoke, use a stiff wire to pull the pin to ground. The component that starts to get hot or releases the magic smoke is likely the one trying to pull the bus up.
Offline A Hellene
  • Country: gr
« Reply #2 on: August 03, 2011, 11:05:57 am »
Well, how about using a Reset Supervisor chip (in a TO3/SOT23/etc. 3-pin package), to be sure?
-George
Hi! This is George; and I am three and a half years old!
(This was one of my latest realisations, now in my early fifties!...)
Offline Bored@Work
« Reply #3 on: August 03, 2011, 11:18:51 am »
It doesn't make sense to throw more hardware onto the problem if you don't know what the problem is. So let me repeat: Measure.
Offline A Hellene
  • Country: gr
« Reply #4 on: August 03, 2011, 11:27:27 am »
[...] (100k down to .5k) [...]
Oops... I thought I read that the pull-down range resistors were 100K .. 5K...
Sorry for that. If a 500 Ohm resistor failed to pull the line down, YES, measure and investigate what the strong pull-up source is.
-George
« Reply #5 on: August 03, 2011, 05:09:04 pm »
Thanks guys. I thought I must be doing something wrong when the pull downs didn't work. I'll measure the current tonight. Fortunately, I don't have to worry about the magic smoke because the bus is guaranteed by it's specification to handle short to ground.
