Author Topic: How to keep USB battery power flowing?  (Read 2594 times)
Offline rea5245Topic starter
« on: April 30, 2022, 06:46:35 pm »
I'm plugging a USB device into a USB battery pack. After a minute or so, the battery stops supplying power.
I've tried two different battery packs, both bought from Amazon a while back, and neither is still being sold.
The device is a USB to 12V "cigarette lighter" converter (https://www.amazon.com/dp/B093KXL19S). After a short while, it loses power, even if I haven't put a load on the 12V side.
If I plug the converter into a USB AC adapter, it stays powered on indefinitely.
Is this a problem of the converter not doing any power negotiation? It seems inconceivable that the battery packs would require it; I would expect them to happily provide 5V and at least 1.5A forever.
Any thoughts?
Thank you.
Offline ledtester
Re: How to keep USB battery power flowing?
« Reply #1 on: April 30, 2022, 07:05:44 pm »
« Reply #2 on: April 30, 2022, 07:48:31 pm »
You may need a "power bank keep-alive" circuit:
Thank you.
I can't add a "keep alive" circuit in my application - everything needs to be off-the-shelf. But if that's just the way these battery packs work, I'll need to let the user(s) know they have to "wake up" the battery.
Thanks.
Offline tooki
« Reply #3 on: May 01, 2022, 05:51:26 pm »
You can get power banks with a low-current mode that won’t shut off. I have one from Anker like that. You hold the button for a few seconds till one of the LEDs changes color. I use that to charge my Bluetooth earphones, which don’t draw enough current to keep most power banks alive
The following users thanked this post: JBeale
Offline tooki
« Reply #4 on: May 01, 2022, 05:57:16 pm »
No.
Well, it is necessary for USB-PD charging at higher voltages. Most decent power banks use “smart” ICs that can detect and negotiate with all the major standards, including the older proprietary standards that predate USB-PD, so that every device can charge as fast as possible.
And they would if you were drawing 1.5A. But you’re not drawing 1.5A and that’s precisely the issue: power banks have power-saving auto-shutoff circuits that look at current draw on the port. If it’s below some threshold value for long enough time, it shuts off. Small devices — like your 12V boost converter without a load — are below that threshold so the power bank shuts off.
