Author Topic: Convert Acceleration into Displacement  (Read 6443 times)
Offline BilloTopic starter
« on: March 16, 2011, 09:41:13 am »
Is there an application that I can use to convert non-linear acceleration into displacement?
The data is acceleration vs time in CSV format.
I then want to view a chart of displacement vs time, either in the suggested application or else save the new data into a CSV file.
Thanks for any help you can give me, Bill.
Offline allanw
    • Electronoblog
Re: Convert Acceleration into Displacement
« Reply #1 on: March 16, 2011, 10:15:39 am »
Just numerically integrate twice to get displacement. Take a running sum of the acceleration*timestep to get velocity, then running sum of velocity*timestep to get position. Should be doable in Excel. More info here:
http://www.google.com/search?sourceid=chrome&ie=UTF-8&q=numerical+integration+excel
« Last Edit: March 16, 2011, 10:17:28 am by allanw »
Alex
  • Guest
« Reply #2 on: March 16, 2011, 12:57:12 pm »
Use the trapezoidal integration method using Excel and double integrate.
If you interested in the overall integral and not individual points, be careful with the integration results as integrations need a constant to be added to the result.
If you are looking at alternating acceleration (eg vibration), make sure your raw data doesnt have a DC offset. If not, force it to have a 0 mean value. Otherwise your displacement will shoot to an unrealistic value over time.
Alex.
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: March 16, 2011, 02:52:25 pm »
here, the least i can do. assuming you are collecting acceleratormeter data convert into acceleration and time interval are provided/calculated.
avst.jpg = the concept
avst.xls = the implementation (rough one)
« Last Edit: March 16, 2011, 03:07:36 pm by Mechatrommer »
« Reply #4 on: March 17, 2011, 08:32:12 am »
WOW !!  Super Replies and Super Fast.
Thanks very much to you all.
Bill
