Author Topic: Disable or trick pulse-skipping/skip-cycle/eco-mode  (Read 2227 times)
Offline b_forceTopic starter
    • One World Concepts
« on: May 22, 2019, 02:47:11 pm »
I have here a power supply with a NCP1239.
I am pretty happy with the overall design around this chip, except for the fact that it goes into some kind of "eco-mode" with light loads.
Unfortunately this is causing all kinds of noise issues in my design (which has a dynamic load).
Before I go for a different power supply, I was wondering if this mode can be tricked somehow?
I am fine trading in some efficiency for this obviously.
I have been searching and looking around for a bit, but can't really find any satisfying solution so far.
(for the record, I am skilled in working with main voltages and designing similar designs myself, so I am only just asking for a solution to disable this mode)
Offline Wimberleytech
Re: Disable or trick pulse-skipping/skip-cycle/eco-mode
« Reply #1 on: May 22, 2019, 03:15:30 pm »
If you are willing to sacrifice some efficiency, just add a fixed load.  Not so pretty, but it will address the problem.  Most likely you have thought of this and have reason not to do it.
« Reply #2 on: May 22, 2019, 03:21:55 pm »
Obviously I have, the problem is that this fixed load has to be pretty big to get out of this eco mode.
Wasting around 1A around 24V.
A little bit to big to my liking, so I was wondering if there other ways to do this?
« Reply #3 on: May 22, 2019, 03:33:01 pm »
Going into skip mode below 1A doesn't feel right.  1A is not "light load"
« Reply #4 on: May 22, 2019, 03:39:17 pm »
Well, around 1A it goes into a lower frequency, around 20kHz which is causing a lot of noise issues.
Going down to around 500mA and this frequency is even lower.
With no load it's completely unusable, go to around 4-5kHz or thereabouts.
This power supply can deliver around 150W, so I guess 24W is considered a light load?
« Reply #5 on: May 26, 2019, 01:28:58 pm »
No other ideas?
Isn't there a way to tick the feedback pin or something?
Offline mikerj
« Reply #6 on: May 26, 2019, 03:26:22 pm »
If you try to prevent the voltage on the FB pin falling low enough to reach the pulse skipping mode, then the supply will become unregulated at low loads and the output voltage will increase considerably.
I suppose you could put an active load across the output that prevents the FB voltage dropping by applying additional load (instead of a a fixed load resistor), but this seems like a lot of additional complexity.  Starting with a fixed frequency controller would be a better plan.
« Reply #7 on: May 26, 2019, 03:44:08 pm »
I know, it's only very difficult to find them these days, since most of these controllers have some kind of green/eco skipping mode built it :(
Offline David Hess
  • DavidH
« Reply #8 on: May 26, 2019, 08:56:30 pm »
Wouldn't increasing the inductance delay the point where pulse skipping mode is active?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #9 on: May 27, 2019, 12:47:49 am »
Keep FB above Vskip (0.8V).
Since FB has an internal pullup, a series resistor between the optotransistor (assuming the application circuit) and FB will do this.
The R_UP doesn't seem to be rated, so YMMV.
Seven Transistor Labs, LLC
Offline mikerj
« Reply #10 on: May 27, 2019, 01:57:36 pm »
But this will cause loss of regulation, unless performed indirectly by adding load.   Additionally the OP want's to avoid the drop in frequency prior to pulse skipping, so FB voltage would have to be limited somewhat higher than 0.8v, as much as 1.9v to avoid any change in switching frequency.
Offline Miyuki
  • Country: cz
    • Me on youtube
« Reply #11 on: May 27, 2019, 04:17:30 pm »
If it is not a consumer product and thus dont need to pass green/eco requirement
Just use simple old UC38xx or similar driver with steady regulation in all range
I dont see any reason to use modern eco controller in situations where it cause instability and other problems when you dont need that low standby power consumption
And that NCP1239 dont look like have any fancy resonant mode to offer benefits in efficiency at full load so it have no benefits for your use
Offline T3sl4co1l
« Reply #12 on: May 27, 2019, 05:45:23 pm »
They asked, that's what the block diagram says. ¯\_(ツ)_/¯
If that solution requires a bleeder resistor, then change the transformer ratio.  Or, check that the transformer's leakage is what it needs to be (which, if light-load regulation is the problem, more leakage might actually be helpful?).
All this ^^^ :)
« Reply #13 on: May 28, 2019, 06:38:31 pm »
To be very honest, I am investigating if I can take an off the shelf PSU.
The reason is that nowadays they are cheap as chips and perform pretty reasonable.
As far as I know, these ECO modes are only to make the people at the government happy that idle power isn't than a certain value.
In our case not a huge problem since the device is being powered of by a hard switch.
But like I said, the biggest problem it has that it goes down to much lower frequencies, which is causing all kings of noise problems.
The issue is that I need the voltage regulation, or at least that it's not going through the roof.
