Without knowing any details, I would assume that the peak inductor current needs to be multiplied by the duty cycle to determine steady current. Actually, this would only be true if inductor current were square. If inductor current is caused by a square voltage, then it's a triangle wave and its resultant dc would be less, no more than 1/3 of the peak, times the duty cycle. All this, neglecting abberrations such as spikes.
