Hi all.
I have a generic 5v supply rail to rail 200A current sensor with a 2.5v = 0 amps output.
0v=-100A and 5V = +100A standard stuff.
The sensor output has a 220R resistor in the circuit inside the sensor.
It feeds into a generic microcontroller adc input so probably has an input impedance of 10k or so.
I want to reduce the sensitivity of the sensor so that I can electronically adjust the sensitivity to give between a say 0 and +50% current increase.
Bypassing it with some of the current is not practicable.
Using two simple 1k resistors tied to the sensor +5v and gnd rails and to the sensor output I can reduce the voltage swings and get and increase in current of around +30% .. All good so far.
However I want to electronically control the modifying rail tied resistors to give say a 256 step change.
Do you think spi digital pots can do the job?
Any better ideas?
Do I need op amp buffers to keep the impedance?
Thanks for the ideas.
