Author Topic: elcheapo driver and LED diybulb best combo  (Read 2463 times)
Offline dave_j_fanTopic starter
  • Country: in
« on: November 03, 2014, 05:52:35 pm »
LED bulb idea
I have got 5630 leds per led is 60LM brightness
means i need 12 leds to get 720 lumens
means i need 4 strings of 3 leds as in the diagram
got 300mA  led drivers for 3x1w spot lights
like this http://www.satisled.com/11w-power-led-driver-ac85v265v-input-dc338v-300ma-output_p1500.html
How do i add current from two drivers ?
wil two strings   work reliably in the constant current driver (not using 555)
else
for the full bulb i will put 2 of the 555 circuits  each feeding from one driver
Point of making the bulb is the quality of the drivers is very good and low cost ,
 smdleds of good quality ihave got
All works fine we will have a 6wattbulb.
I thought of making it like a mini tube .
please suggest better alternatives !
This will go working with the LED inverter i made
Offline Marco
Re: elcheapo driver and LED diybulb best combo
« Reply #1 on: November 03, 2014, 06:31:41 pm »
You're all over the place, you have a schematic with 12V supply and then you mention using constant current AC-DC supplies, then you mention an inverter you made.
If you have those drivers already and the 5630 LEDs are designed for ~150 mA, what I would do is put two strings of 3 with current sharing resistors or a current mirror on each driver ... no need to parallel the drivers then.
I don't know if those constant current drivers will appreciate being PWM dimmed.
« Last Edit: November 03, 2014, 06:36:22 pm by Marco »
Offline Corporate666
  • Remember, you are unique, just like everybody else
« Reply #2 on: November 03, 2014, 11:16:13 pm »
It's not going to work like you are thinking...
According to the link to the drivers, they are AC input and output 3 to 3.8V DC with a 300mA constant current.  So you're not going to be able to drive a string of 3 or 4 white LED's with that driver.
Also, those 5630 LED's are rated for 150mA, but they will need quite a bit of heat sinking at that temperature, and it's not their most efficient by far.  You would do well to run them more like half that value for better efficacy and longer life (and less heat).  Of course, you'll need more LED's, but them's the breaks.
If I were doing this, I'd use a standard AC->DC "wall wart" power adapter to get down to something like 24 or 36 volts and then build and CC LED driver with DC as my starting point.
Or, if I was looking to buy something off the shelf, I'd start with an AC->DC LED driver, like something from these guys -> http://www.trcelectronics.com/
I most definitely would not mess around with exposed AC->DC drivers from a Chinese source if I wasn't very very sure about exactly what I was doing and how to do it safely, and I suggest the same to you.
It's not always the most popular person who gets the job done.
  • Country: in
« Reply #3 on: November 04, 2014, 09:57:37 pm »
Thank you marco
 i intended  to work out a middle path ..not too expensive yet a reliable one
 i made few 2transistor LED desk lamp that runs off the cell charger
 gives 10hr backup with simple components i.e. a powerbank  here lot many (1000+) poor and hostel students
 took that idea!!
so i posted the dc driver circuit to keep design simple
I also have pt4115 led drivers .
Corporate666
 *very sorry for the wrong link to the driver type  This is the suitable link -->
 The driver is designed for spotlight use http://www.satisled.com/31w-power-led-driver-ac85v265v-input-dc914v-300ma-output_p206.html
china drivers are  NOT from the same vendor , i got from a leading china firm they do all types of LED lights
Today tested the leds ...good   pretty bright lights from 7LEDs  yes  @ the favorite brightness the leds get pretty hot
How about if i mount them on heattransferring silicon rubber and solder with enamelled wire .
need to device a trick to glue them
kepton tapeshould work or i will make a aluminum jacket from coke can foil
worked with smd5050 they run cool but pain to solder..
many led half current trick also will consider
