Author Topic: MIPI DSI over 1-2 meter distance  (Read 1175 times)
Offline ricko_ukTopic starter
« on: September 20, 2024, 01:51:13 pm »
in the board I am designing I am driving this display which has a MIPI DSI interface: https://www.panelook.com/upload/product/243585/202403251897.pdf
After doing a bit of research it looks like MIPI DSI can only run reliably over a maximum distance of around 30cm or so. But because of mechanical constraints, the PCB might need to be placed at around 1 to 2 meters away.
Because the display will display video, I assume the software will configure the clock to run at its maximum speed.
What is the best solution to transmit that signal over that 1 to 2 meters distance?
Thank you
Offline DavidAlfa
Re: MIPI DSI over 1-2 meter distance
« Reply #1 on: September 20, 2024, 02:01:22 pm »
ADV7533 MIPI-HDMI bridge? Then whatever converts it back to MIPI.
The following users thanked this post: Smokey
Online Postal2
  • Country: ru
« Reply #2 on: September 20, 2024, 02:43:37 pm »
... MIPI DSI ... at around 1 to 2 meters away. ...
No solution. In my case clock 200 MHz, I tried to connect display to Orange-IOT, no one helped (no any advice at all). To use dsi-hdmi you need change driver in firmware.
Offline jas_G
« Reply #3 on: October 02, 2024, 12:02:13 am »
Hi, did you have any luck with this? I am looking into a similar problem - there doesn't seem to be two many
HDMI-MIPI/DP-MIPI/LVDS-MIPI ICs. Looks like mostly FPGA solutions or RGB/MIPI conversions...
Online Postal2
  • Country: ru
« Reply #4 on: October 02, 2024, 04:20:54 am »
There is a solution. You can use a viewing tube with a camera on one end and a display on the other, and adjust the camera to the display that needs to be extended.
You can also use a neatly cut bundle of fibres from the optical internet as a light guide, or a ready-made light guide of this type.
Or any type of optical transmission with lenses and mirrors. Similar to a LCD projector.
« Last Edit: October 02, 2024, 04:36:07 am by Postal2 »
« Reply #5 on: October 03, 2024, 12:53:02 am »
Thank you all.
@jas_G,
we are now looking into modifying the mechanics to keep the PCB next to the display (for a number of other reasons). But the options suggested above, unless you have very large displays running at very high clocks, they should work.
« Last Edit: October 03, 2024, 12:56:41 am by ricko_uk »
Offline dmendesf
  • Country: br
« Reply #6 on: October 03, 2024, 02:25:32 am »
Offline squadchannel
  • Country: jp
  • deepl translate user
Online Postal2
  • Country: ru
« Reply #8 on: October 03, 2024, 06:44:55 am »
There is no talk of 2 meters (redriver):
  • Country: jp
« Reply #9 on: October 03, 2024, 08:58:39 am »
I think most retimers assume it's not a long distance, about the distance between a laptop webcam and the motherboard. the TI datasheet has a picture.
I don't think 2m is possible.
Well, he says he will change the design so it will be solved.
« Reply #10 on: October 04, 2024, 03:22:29 pm »
Thank you all for the feedback. :)
And also very interesting additional infos in your latest replies.
Offline alexk195
« Reply #11 on: October 05, 2024, 01:09:58 pm »
Have you looked at FPD link from Ti or GMSL from Analog devices?
« Reply #12 on: October 05, 2024, 09:36:16 pm »
Thank you @alexk195,
those are also interesting solutions.
Good to know for future projects.
