Author Topic: Board to board connector with jumpers  (Read 2679 times)
Offline wigman27Topic starter
    • Wiggins Wonderful Websites
« on: August 12, 2014, 12:27:39 pm »
I am currently designing a project that I am hoping to make modular and require some board to board connectors, I have had a look at a few other threads on here that discusses this and they are great but I need mine to have jumpers. Sometimes I will want to make the connection and sometimes I don't.
I am trying to combine the connector and the jumpers into one device. I am currently looking at using these and soldering them to the board.
Connector
Jumper
At the moment I need approximately 24 connections and will have a maximum clock signal of about 30MHz.
Is there a better option?
Lee
Need a website designed? Check out my Australian based web development business www.wigweb.com.au for affordable fixed price packages
Offline mariush
Re: Board to board connector with jumpers
« Reply #1 on: August 12, 2014, 01:40:06 pm »
If they're good enough for USB 2.0 and USB 3.0, they'll probably be OK for connecting your boards.
Offline void_error
  • I can transistor...
« Reply #2 on: August 13, 2014, 09:28:41 am »
It's probably the cheapest way too. The maximum clock signal you can push through depends mostly on your PCB design (and the devices used, of course). A good practice is to keep the high speed traces short.
Trust me, I'm NOT an engineer.
« Reply #3 on: August 13, 2014, 09:31:42 am »
Cheapest isn't really my preference in this particular case so if you know of an alternative then I would be happy to hear it!
What sort of frequency would you consider high speed? when does it cross that "boundary"?
Offline void_error
« Reply #4 on: August 15, 2014, 09:21:44 am »
There's no defined boundary, since it depends on a particular case. Every PCB trace (or piece of wire) has resistance and inductance, and two adjacent traces form a capacitor. At low frequency this usually doesn't matter. The signal source's output resistance might also matter.
Offline tszaboo
« Reply #5 on: August 15, 2014, 10:11:58 am »
Samtec has some measurement reports on their similar connectors. I remember it is in the "few GHz" region for the -3dB.
Offline David Hess
  • DavidH
« Reply #6 on: August 15, 2014, 09:06:51 pm »
Those are the type of connectors I would use.
Pin headers with 0.1 inch spacing are good enough for clean 100 MHz performance in oscilloscope vertical amplifiers so they are good to at least 500+ MHz when used appropriately.
