Author Topic: Looking for small QFP-160 socket  (Read 661 times)
Offline romhunterTopic starter
  • Country: vn
« on: September 23, 2019, 09:00:37 am »
Hello, I'm currently using a clamshell QFP-160 socket in my design (Part no# QP1-160065-009). The size of the thing is 30.3*30.3 (cm). I'm just asking if someone know a smaller socket? It took a bit of space, and I'm trying to reduce the size of the PCB. Any type of socket, not necessary clamshell.
Thanks in advance.
Offline TomS_
Re: Looking for small QFP-160 socket
« Reply #1 on: September 24, 2019, 06:58:23 am »
30cm square?? Did you mean 30mm?
I would think that once you get to a basic level of functionality that works reliably you could design a board that doesn't need a test socket.
Keep a board with a test socket for development purposes, but look to progress beyond.
