Author Topic: Industrial soldering Handbook  (Read 3237 times)
Offline salvodi89Topic starter
« on: April 26, 2015, 08:48:26 am »
Hello Everyone,
I'm looking for a good handbook for soldering and PCB assembly in industry.
I'm interested in particular in hand soldering/reworking, solder inspection.
Does anyone had experience with that? Is there any good book as reference?
Thanks!
Offline robgambrill
Re: Industrial soldering Handbook
« Reply #1 on: April 26, 2015, 04:43:40 pm »
This might be a start. NASA has this guide....
http://www.hq.nasa.gov/office/codeq/doctree/canceled/NS87393-Ch5.pdf
It is no longer in effect, but it shows requirements for soldered electrical connections as formally required in NASA equipment. From the foreward...
This Standard provides a baseline for NASA project offices to use when preparing or evaluating
process procedures for the manufacture of mission hardware or mission critical ground support
equipment.
Offline 128er
« Reply #2 on: April 26, 2015, 05:02:21 pm »
And here is some more NASA stuff. Not only about soldering techniques:
http://workmanship.nasa.gov/lib/insp/2%20books/frameset.html
« Reply #3 on: April 26, 2015, 05:50:00 pm »
Thank you!
Both the links you provided are really amazing.
That's the kind of things you expect from nasa... but... how did you find these things?
Offline pickle9000
« Reply #4 on: April 26, 2015, 05:59:19 pm »
Mr. Scott (James Doohan) syndrome.  :-+
« Reply #5 on: April 27, 2015, 02:13:26 pm »
I found these book:
Did anyone had read one of these books?
What do you think?
Offline ivaylo
« Reply #6 on: April 28, 2015, 06:29:45 am »
There is this http://www.elektor.com/mastering-surface-mount-technology by a forum member here...
Offline BradC
« Reply #7 on: April 28, 2015, 06:49:01 am »
Wow, that takes me back. We did a unit to those standards back when I was at TAFE 20 years ago. I still remember the little lead formers and clippers required to ensure the lead was appropriately trimmed prior to soldering so as to not leave any raw copper exposed. That course did my soldering quite a bit of good actually as it taught you the basics of heat transfer and how to make the most appropriate joint in the minimum of time to limit heat input.
