Author Topic: CP2102N USB to Serial Converter  (Read 469 times)
Offline alaa2003Topic starter
  • Country: eg
« on: December 04, 2023, 09:06:06 pm »
Hello
anybody tests this ttl converter with version A02 chip, which supplier you advice.
I prefer the item should has two led for tx,rx indicator & programmable
https://www.silabs.com/documents/public/data-sheets/cp2102n-datasheet.pdf
« Last Edit: December 04, 2023, 09:15:38 pm by alaa2003 »
Offline tooki
Re: CP2102N USB to Serial Converter
« Reply #1 on: December 04, 2023, 10:28:21 pm »
What’s your question exactly?
I’ve used that chip in several projects of my own, and it’s the chip used in most (all?) of the ESP32 dev boards sold by Espressif, so super widespread.
The manual shows the TXT/RXT pins (RX/TX LED pins) on page 23.
