Author Topic: CPLD erase from Airport X-ray scanners  (Read 4066 times)
Offline EEEnthusiastTopic starter
  • Country: in
  • RF boards, Precision Analog, Carpentry
    • https://www.zscircuits.in/
« on: February 02, 2020, 11:49:16 am »
Has anybody experienced a complete erasure of a CPLD logic when it passed through an airport X-ray machine? Or may be some other scanner used in the airport?
Making products for IOT
Offline T3sl4co1l
    • Seven Transistor Labs
Re: CPLD erase from Airport X-ray scanners
« Reply #1 on: February 02, 2020, 04:38:26 pm »
FYI, I've passed my laptop through, in standby, with no apparent change in operation when later opened.  (That would be a target size of, less than 1GB I think, of active, in use, RAM.  Data that I would expect might cause a crash if it gets corrupted.) I would expect DRAM to be more vulnerable to EEPROM cells, or some Flash.  (I wouldn't think CPLDs are using the latest, highest density Flash processes, no?)
AFAIK, erasing EEPROMs is possible with x-rays, but only with extreme levels, levels that cause rapid and permanent damage to the chip.  Whereas electronic erase cycles might be 10^5, or UV cycles might be 10^3, x-ray cycles are like... 10^1 if that.  Or something.
Also AFAIK, most programmable devices are rated for assembly inspection x-raying, which are probably around the same level??  I can't remember actually reading such a rating actually, but it must exist?  There are plenty of no-lead packaged devices out there, that would need to be x-rayed, that can be supplied pre-programmed.  Which means they need to retain their programming through soldering cycles, too.
Seven Transistor Labs, LLC
The following users thanked this post: boB
Offline SiliconWizard
« Reply #2 on: February 02, 2020, 04:48:18 pm »
I've done that many times too and never experienced any issue. Even when left in standby.
AFAIK, erasing EEPROMs is possible with x-rays, but only with extreme levels,(...)
I'll say yes and yes.
And I'd say typical inspection x-ray machines have significantly higher level.
Online magic
« Reply #3 on: February 02, 2020, 07:07:34 pm »
There is also a whole bunch of actual EEPROMs and Flash in computers and other consumer electronics which go through those scanners.
Offline filssavi
« Reply #4 on: February 02, 2020, 07:39:30 pm »
I fly fairly often, so I have USB keys, sata SSDs (MLC), laptops and tablets go through x ray scanners 5/10 times a year and I have never had any problems. I expect CPLDs to be much less susceptible as they are usually manufactured on very old nodes (the older the node, the larger the feature size, the higher the energy needed to flip a bit)
Also I think complete erasure is basically impossible, unless you exposed the memory to extreme levels of radiations (nuclear reactor type levels), I would expect more of an erratic behaviour due to single bit flips (I seriously doubt CPLDs do crac checks on startup)
Anyway airport scanners are allegedly designed to be film (as in photographic film under ISO800 sensitivity) safe, and I expect that to be quite more sensitive than flash
Online LaserSteve
« Reply #5 on: February 02, 2020, 08:15:47 pm »
I've worked for two employers where medical/safety of life grade boards were hand inspect no-xray , when shipped. This wss for good reason.
The cargo grade machines are upwards of 260 KV at a LOT of maS, rated to see through 70 mm of steel. I'vr had older PICs and some modern FPGAs , as well as 80 ISO panchromatic film trashed by cargo x-ray in a past life. We carried JTAG programmers in our toolkits for a reason.
Really fun fact. Our packaged film, used for laser beam analysis, came in custom cardboard boxes with the company logo on them. The metal oxides in the logo colors interacted with the x-rays and I'd open the film packs to find five or so plates with a dark latent print of the logo showing without development.
Steve
« Last Edit: February 02, 2020, 08:21:17 pm by LaserSteve »
"When in doubt, check the Byte order of the Communications Protocol, By Hand, On an Oscilloscope"
Quote from a co-inventor of the PLC, whom i had the honor of working with recently.
The following users thanked this post: Miti, I wanted a rude username
Online ebastler
« Reply #6 on: February 02, 2020, 08:29:16 pm »
Your questions makes me curious. I assume you are asking since you did experience difficulties with an erased CPLD? Could you describe the affected device and the circumstances, and whether you are sure that is was damaged due to handling at the airport?
  • Country: in
« Reply #7 on: February 03, 2020, 03:02:32 am »
Well, in this case it was an Altera CPLD which was erased/corrupted. This was about couple of years ago when some boards were shipped to the USA from India. These were recovered after re-flashing the CPLD. I cannot be 100% sure if it was the airport handling which caused it or it was not programmed to begin with for which the chance was very small. There was no other event which could erase the code and hence the airport scanner was the primary suspect. I was wondering if the high enough radiation power can displace the electrons and cause some bits to change which could modify the logic programmed. Especially if the exposure time is long enough.
There are some reports available which shows that flash memory could be corrupted with high dose X-rays. But I could not find any info on CPLD.
https://www.cypress.com/file/202521/download
Online David Hess
  • DavidH
« Reply #8 on: February 03, 2020, 04:46:39 am »
Like T3sl4co1l says, x-rays will erase floating gate memory but it takes quite a dose.  An awful lot of consumer electronics goes through airport x-ray machines and multilevel NAND Flash is a lot more sensitive than a floating gate programmed CPLD.
Maybe someone left the package in the x-ray machine for an extended inspection?
Online LaserSteve
« Reply #9 on: February 03, 2020, 05:59:20 am »
Boards from the US warehouse which was in plant were blank to begin with. Boards from the Indian logistics warehouse were the ones with glitches. India seems to be a great place for overnight emergency shipping of medical parts to the US for some reason.
Edit:  The. Boards stored overseas were flashed and verifed before leaving the US.  Stored in exquisite ASTAT packing and packed in boxes with world class shock proof padding. Not a chance of mishandling. Multiple FPGA in the programming chain would read corrupted when the checksum was computed.
The film exposures were in the US.
So were the PICs.
Steve
« Last Edit: February 03, 2020, 10:29:19 am by LaserSteve »
  • Country: in
« Reply #10 on: February 03, 2020, 09:45:12 am »
So were the PICs.
Steve
That explains some of it. I have had 2 instances of the boards getting corrupted and both of the time, it originated in India and destination was the USA. It might just happen that all the shipments to the USA are scrutinised more and so they spend more time in the X-ray machine at high power levels. Any time the guys at the customs see an electronic part, which they cannot recognise, they suspect it to be some kind of a bomb set to explode on the flight.
Offline Psi
« Reply #11 on: February 03, 2020, 10:02:34 am »
About 12 years ago I was contracted to write a small report into the safety of consumer electronics going through airport xrays.
The airport staff wanted some factual data/evidence when dealing with customers who insisted the xray machine had damaged their device or data.
For the first test I put a hard disk, a floppy disk and USB drive through the machine 5 times and checksum'ed them before/after to confirm data integrity.
Then i sat them on the xray window inside the tunnel with the conveyor off but xrays forced on.  They were in the xray beam continuously for a time that equaled around 9000 cycles through the machine normally. They still all checksum'ed correctly.
« Last Edit: February 03, 2020, 10:05:40 am by Psi »
Online LaserSteve
« Reply #12 on: February 03, 2020, 10:31:59 am »
Did you run that test as cargo or checked/carry-on?
My glitches are ALL cargo.
Steve
  • Country: in
« Reply #13 on: February 03, 2020, 12:26:35 pm »
Steve
It was all cargo mode...
Offline Psi
« Reply #14 on: February 03, 2020, 06:26:54 pm »
Steve
My tests were using the carry-on baggage xrays
  • Country: in
« Reply #15 on: February 04, 2020, 03:51:44 am »
I guess the cargo X-rays are much stronger than the carry on ones. The cargo X-ray machines are larger as they scan through larger consignments and it makes sense to make the X-rays stronger for them to see through metal sheets.
Offline texaspyro
« Reply #16 on: February 04, 2020, 05:10:28 am »
There is a company (can't recall who) that makes a line of precision voltage reference chips that use the charge in a floating gate to set the voltage.   They have a report on how x-rays affect the voltage.  Also saw some independent tests.   I seem to remember the results said the technology was not all that precision.
  • Country: in
« Reply #17 on: February 04, 2020, 05:15:30 am »
Next time I will put a 2 inch solid lead block over my CPLD....
Oh...wait a minute... that will violate LEAD free rules... I'm screwed now..  |O
Offline texaspyro
« Reply #18 on: February 04, 2020, 05:23:40 am »
Tungsten or tantalum works better that lead
Offline BravoV
  • +++ ATH1
« Reply #19 on: February 04, 2020, 05:38:58 am »
Former Intersil (now Renesas), their product line of voltage references that use Floating Gate Array is affected by X-Ray.
-> AN1533: X-Ray Effects on Intersil FGA References
Interesting quote :
"Shielding and PC board solutions. The FGA package leadframe plus two planes of copper provide an excellent shield for radiation from one direction as shown in Table 5 on page 4. Protection for the device side of the board must also be considered. A shield of zinc foil or sheet, 250µm minimum can be placed inside the enclosure above the FGA which effectively filters the most damaging energy. An alternative to consider is a thick aluminum sheet, 10mm or greater, placed over the device side of the PC board."
« Last Edit: February 04, 2020, 05:43:05 am by BravoV »
Offline filssavi
« Reply #20 on: February 04, 2020, 05:49:46 am »
Yes that will succeed 100% of the times in getting your baggage stopped and opened by TSA or whoever in order to check that the lump of metal is not a battery bank or something  :-DD
Offline filssavi
« Reply #21 on: February 04, 2020, 05:54:14 am »
If you really need the CPLD to withstand strong x-rays you can get the space rated ones, they shoul be able to shrug off anything an airport throws at them with ease.
It won’t be neither cheap nor easy to get
  • Country: in
« Reply #22 on: February 04, 2020, 05:58:33 am »
Based on the inputs, it looks like an aluminum heat sink over the CPLD may be the cheapest solution for the problem. They are easy to buy and install..
Not sure of Zinc sheets, will check if they are available online.
Offline BravoV
  • +++ ATH1
« Reply #23 on: February 04, 2020, 06:08:57 am »
Not sure if this can be used, long time ago when I did DIY Zinc electro plating, I bought big chunk of Zinc block, that usually used for sacrificial anode for sea water vessels like ship, they're dirt cheap and easily sourced, especially near shipping dock/yard area as they're consumable.
Random image from Google
Online ebastler
« Reply #24 on: February 04, 2020, 06:40:07 am »
How would that protect against x-rays coming from other directions? I understand that cargo is often screened in CT-type x-ray scanners.
