It has been suggested to me that I need slew rate limiting on the voltage from a CR2032, when the battery is changed as the low ESR caps are discharged and a relative high inrush occurs that can cause ringing leading to the potential to exceed the micros absolute max voltage
I would have thought the relatively high ESR of a typical CR2032 lithium cell would self limit
whats the collective wisdom on this , The suggestion being to add a SIP32431 inrush/slew rate limiter chip
Thanks
