Author Topic: CRD alternative  (Read 724 times)
Offline ArturNTopic starter
CRD alternative
« on: August 17, 2019, 12:17:40 pm »
Hello,
Recently i designed some device in which i needed to limit current.
I used CRD (Current Regulative Diode).
For example this:
https://pl.mouser.com/ProductDetail/Semitec/S-202T?qs=sGAEpiMZZMtjJbtednZihoE8nwVXbu0d
My question is that what is the cheapest alternative to this device?
I found only current limiter based on JFET's.
Any ideas? :)
Offline David Hess
  • DavidH
Re: CRD alternative
« Reply #1 on: August 17, 2019, 07:35:49 pm »
I assume you mean exclusively for two terminal devices.
LM317s can be configured to provide a constant current.  The LM334 is an integrated current regulator.  Depletion mode MOSFETs can be used in place of JFETs.  The LM10/LT1635 operational amplifier and reference is also useful as a basic building block to make current regulators.
Offline Benta
Re: CRD alternative
« Reply #2 on: August 17, 2019, 09:36:06 pm »
J507
Offline NiHaoMike
    • Facebook Page
Re: CRD alternative
« Reply #3 on: August 18, 2019, 05:01:25 am »
Depending on the circuit requirements, you might be able to use a current source based around a bipolar transistor, two diodes, and two resistors.
