Author Topic: H bridge doesn't draw any current from supply  (Read 609 times)
Offline DmeadsTopic starter
  • who needs deep learning when you have 555 timers
« on: August 18, 2019, 02:24:12 am »
Hi all! I am building my first H bridge for an spwm signal.
You can see via the picture, but here is another description:
I have an FPGA that generates the different duty cycles needed to make a sine wave. Data one in the pic generates one half of the wave while data 2 generates the other. The Verilog is solid, I highly doubt that is causing the issue.
I have four irf724n mosfets with 10k ohm pulldowns at the gate, the load is connected across as in the pic.
The trouble is, no matter what voltage supply I connect to the H bridge, the signal remains the same size and is very not sinusoidal. Also no matter the load it doesn't draw any current (or so small my meter can't read it).
Any thoughts? Thanks!
Offline ledtester
Re: H bridge doesn't draw any current from supply
« Reply #1 on: August 18, 2019, 02:34:09 am »
Maybe you should have pull-ups on the upper arms of the H-bridge?
The following users thanked this post: Dmeads
Offline Circlotron
« Reply #2 on: August 18, 2019, 02:44:50 am »
If the upper mosfets are only being driven with +5v to the gates, same as the lower ones,  then the sources of those upper mosfets will be lucky to rise to more than +2V. The gate drive for the upper mosfets gates needs to be referenced to their sources, not referenced to ground.
The following users thanked this post: NiHaoMike, Dmeads
« Reply #3 on: August 18, 2019, 03:17:54 am »
got it working!
not perfect but not bad either!
thanks!!
