Boomers come up with electrical schematics to simplify the drawing as much as possible and focus on what matters.
A 3D render gives the impression that something has been done, but in reality, very little has been done:
Your project should include some kind of speed controller. 100 years ago, a series of resistors switched by contactors were used. Nowadays, electronic controllers are used.
The AI assistant is also educated to assist or even make new novel designs I request.
Use AI for what it's good for - to assist in learning. Don't ask for a ready-made project, ask about the properties of motors, methods of speed regulation, and direction change. Ask about how to measure the motor's characteristics, how to select the gearbox. Ask about what you can verify in other sources. Ask how to find information that might be useful to you but of which you are not yet aware. Ask what difficulties you might encounter when designing the propulsion system of such a vehicle.
Don't be a mindless robot executing the commands of a stochastic machine.
We will verify the quality of your thinking when AI provides you with incorrect data.
