Author Topic: Critique my first PCB  (Read 5293 times)
Offline carl0s
Re: Critique my first PCB
« Reply #75 on: August 10, 2019, 07:54:46 am »
Thanks for the pictures. I have a couple of the 480*480 HX8379-C coming to have a play with.
I think because they are GRAM-less, they are operated in Video mode, where hsync and vsync is sent along with raw pixel data, so no tearing effect line is used.
The 320*320 panel that I have been using (st7796) has a GRAM/framebuffer and works in adapted command mode.
Check ST application note AN4860.
This is the same as my 800*800 ILI9881C screen, which I have not used yet because it requires 3 lane MIPI.
Carl
Offline luiHS
    • Pinballsp
« Reply #76 on: September 19, 2019, 03:17:43 am »
How are you doing with your tests with the round screens? I have already designed the PCBs to use the two 2.1 and 2.4 inch screens.
What I do notice when testing the 2.4 screen is that there is a certain Tearing effect, as if the TE signal was not being used, that makes when playing videos, when scenes with rapid changes come out, a certain cut is shown in the middle of the screen .
The 2.4 screen is much brighter than the 2.1 screen, and although it has less resolution, I think it looks better.
« Last Edit: September 19, 2019, 03:20:53 am by luiHS »
Offline carl0s
« Reply #77 on: September 19, 2019, 11:38:33 am »
Hey Lui
Great work. I can see the tearing too..
Is that stm32F769 with mjpeg video? I think it looks great.
I have done zero work really. I am still playing with SSD2828 bridge for the 4-lane display. No real reason other than to not give up. but it's just a part time hobby for me and I'm just too tired in the evenings lately to do anything :)
I agree the 320*320 Panasys screen is great and bright.
What about the 480*480 one with the 0.2mm pitch connector? I have a couple of those, but no breakouts for the connector yet and not bothered about having a PCB made just yet.
Carl
Offline carl0s
« Reply #78 on: September 19, 2019, 11:44:53 am »
Are you sending the TE enable DSI cmd? (DSI_SET_TEAR_ON)
I have found that I don't get any screen output without it.. not sure if I mentioned that on here previously.
« Last Edit: September 19, 2019, 06:09:23 pm by carl0s »
Carl
Offline luiHS
    • Pinballsp
« Reply #79 on: September 19, 2019, 07:44:43 pm »
Hey Lui
Yes, my PCB boards are with the 769, in addition to an SDRAM, SD card holder and backlight voltage booster.
About the connectors, the 320*320 2.1-inch screen needs a 0.5 mm pitch connector, and the 480*480 2.4-inch screen needs a 0.3 mm pitch connector. Both connectors available in Mouser.
« Last Edit: September 19, 2019, 07:46:23 pm by luiHS »
Offline luiHS
    • Pinballsp
« Reply #80 on: September 19, 2019, 07:46:03 pm »
I will check it, I do not remember now.
Offline carl0s
« Reply #81 on: September 20, 2019, 03:36:33 pm »
Hey Lui
Cool.
Yes I have the connectors.
« Last Edit: September 20, 2019, 03:38:20 pm by carl0s »
Carl
Offline luiHS
    • Pinballsp
« Reply #82 on: September 20, 2019, 08:18:29 pm »
I receveid my new PCB for the 2.1 inches round screen. Ready to assemble and test.
Next week I will receive PCB for the 2.4 inches, I hope I can solve the TE problem, its a good round screen, good size and very bright, but the tearing effect spoils something when playing videos with fast movements.
Offline carl0s
« Reply #83 on: September 20, 2019, 08:38:11 pm »
 In your video it is the 2.4" screen already. Ha, I wondered about that.. the connector is going under the piece of paper isn't it?
Carl
Offline luiHS
    • Pinballsp
« Reply #84 on: September 21, 2019, 12:09:30 am »
The first tests were with an HDMI controller board, to check the resolution and brightness of each screen.
Now I go with the PCBs that have all the electronics based on the 769, and connect with 3 wires, 2 wires for 5 volt power supply and a third wire for a serial port to control which videos are played.
« Last Edit: September 21, 2019, 12:13:32 am by luiHS »
