Author Topic: Need J-TAG or not ?  (Read 815 times)
Offline Md Mubdiul HasanTopic starter
  • Country: kr
  • Lets learn more to be more inspired in Electronics
Need J-TAG or not ?
« on: April 29, 2019, 06:35:49 am »
Currently I am working IAR 7.80.2 1 months trial version.
I need some help.
Currently I am  trying to download firmare of WIFI module  through a USB serial COM port.
I have SDK firmware for this wifi module.
This module wifi module has...
1. On-chip PA, LNA, and RF Switch
2. Connection Manager for Autonomous and Fast Wi-Fi Connections
3. Built-in Hardware Crypto Engines for Advanced Security
4 . 16-bit Sigma-Delta ADC : Differential 2 Channels
     12-bit SAR ADC : Single-Ended 4 Channels
5. Supports Various Interfaces
– eMMC/SD Expanded Memory
– SDIO Host/Slave Function
– Quad-lane SPI for External Flash Control
– 2 Universal Asynchronous Receivers and Transmitters(UARTs)
– Serial Peripheral Interface(SPI) Master/Slave Interface
– Inter-Integrated Circuit(I2C) Master/Slave Interface
– I2S for Digital Audio Streaming
– Pulse-Width Modulation(PWM)
– Individually Programmable, Multiplexed GPIO Pins
– JTAG
Right at the moment, I need to check weather my WIFI module can split its data in smart phone APPs or can be connect in AWS cloud.
In the Debugger category, generally the driver selects an available debug probe via the SWD or JTAG interface.
It can not be used when writing firmware via serial communication.
Practicaly I have connect this module to serial port by SECUIRE CRT,but no data has recieved !
To activate the 4 image files are necessary. This image has SFDP (Serial Flash Discoverable Parameter) of the serial flash which is installed on WIFI
module and runs the active RTOS image.
Secondary bootloader
RTOS
RAM Library
PTIM
I think, UART is not a possible for bootloading, what do you think ?
JTAG is not necessary?
Hasan
Offline bson
Re: Need J-TAG or not ?
« Reply #1 on: April 29, 2019, 03:58:34 pm »
Depends on the primary bootloader as installed from the factory.  Anything that runs over a UART is a firmware feature; JTAG/SWD is a hardware feature.
The following users thanked this post: Md Mubdiul Hasan
  • Country: kr
« Reply #2 on: April 30, 2019, 12:43:51 am »
So kind of you Mr.bson!
Form factory in case of mass production, boot-loader is must I think even my co-worker does not believe GTAG is necessary.
This WIFI module datasheet is confidential as I heard.
I think it has enough memory,
ROM : 192KBytes
SRAM : 1664KBytes
OTP : 16KBytes
Retention Memory : 28KBytes
This company also provide an EVM board, but right at this moment I dont have it.
This module is connected with that EVM board which has also a main MCU.
I think that MCU talk in SPI/UART mode to that WIFI module.
Hasan
