Don't want to shut the engine down, just stop the train. I *THINK*, but haven't confirmed this, that shutting the engine down would stop the pump in the hydrostat, with unknown consequences. I think that shutting the engine down would immediately lock the hydrostat, thereby locking the wheels on the loco. Would for sure result in spilling passengers all over the place, and most likely derail the train. I have called this eStop, because I'll use a small eStop switch, but this will be for more than just emergency stops.
The operational problem here is that the linear actuator which moves the bellcrank on the hydrostat moves very rapidly. If I had my druthers (but I don't) I'd have bought a slower actuator. But I've never seen any options in the catalogs for actuators of different speeds. And the actuators were included with the engine, so I'm stuck with them, at least financially. If one is sitting in the station and just holds the toggle switch forward, the train will leave the station with a very big lurch, which would NOT encourage the passengers to come back. Same thing with stopping. One changes the speed of the train by doing repetitive small bumps on the toggle switch, asking for very small speed increases at a time.
When it's time to stop, one bumps the toggle switch to the rear a little at a time. One problem is that there is no easy way of knowing when you have reached the "neutral" point on the bellcrank. Several guys have put in linkages with multiple micro switches to indicate which direction the bellcrank is pointing, and when neutral is reached. All of these tend to be finicky, especially as the rotational travel on the bellcrank is only about 20°, and the linkage is a bit long and the microswitches are somewhat remote from the bellcrank itself.
Hence, I want to use a pulse width modulator to generate pulses so that the engineer can just push the toggle and just hold it, more or less. And using a "speedometer" to measure speed and direction of rotation would more reliably (I think) let a computer find the neutral position.
Why so many conductors? There are three linear actuators, and one needs to feed them in either polarity to make them go in either direction. Most guys are using multiple relays to accomplish this.
The headlight needs to operate in either dim or bright, depending on direction of travel. Air brake controller for the train, operate the compressor, and operate the air release. Parking brake for the locomotive. Bell. Horn. And several different lighting circuits.
I plan to move the existing ignition switch and starter control to the rear of the engine and hard mount it there. The ignition switch seems to only ground the ignition coil, and results in a big load. Could possibly put a big relay on it, but probably won't. Also need a battery cutoff switch, which will also be mounted on the locomotive.
Tom
