Author Topic: 'Driverless' USB Serial ICs: drivers included as default Windows, Mac & Linux?  (Read 10241 times)
Offline TJ232
  • www.esp8266-projects.org
    • ESP8266 Projects
thanks all,
surely if designing from scratch, getting official FTDI is as easy as going a proper distributor, say through Octopart?
@TJ232
whats your chips of choice?
Mostly Silicon Labs ones.
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
Offline janoc
thanks all,
@TJ232
Or the Microchip MCP2221 series of chips. Also the Chinese CH430 bridge is good, but getting it through some official channel may be a challenge.
Offline Matir
    • SystemOverlord
Is there a good alternative for the MPSSE uses in the FT*232 series?  Looking for things like building JTAG adapters, I2C/SPI support, etc.
Offline janoc
I think not a direct replacement, but I believe Microchip has a series of USB bridges that include also I2C/SPI support. It is basically a pre-programmed PIC.
