Author Topic: Crystal SMD packaging...  (Read 2841 times)
Offline alank2Topic starter
« on: June 15, 2014, 06:15:01 pm »
Hi Everyone,
Is there a benefit in terms of reliability between a can type crystal modified for SMD, or one that looks like other SMD parts?
http://www.digikey.com/product-detail/en/ABLS-8.000MHZ-B4-T/535-10212-1-ND/2184247
http://www.digikey.com/product-detail/en/NX8045GB-8.000000MHZ/644-1018-1-ND/1128890
Thanks,
Alan
Offline marshallh
    • retroactive
Re: Crystal SMD packaging...
« Reply #1 on: June 15, 2014, 06:19:26 pm »
Have used both with no difference detected in both reflow and hand soldereing
Verilog tips
BGA soldering intro
Offline rob77
  • Country: sk
« Reply #2 on: June 15, 2014, 06:25:12 pm »
they might have different stability ? according to my experience (talking about cheap xtals) : the smaller the package - the higher the ppm is. but i might be wrong ;)
Offline theatrus
« Reply #3 on: June 15, 2014, 06:36:02 pm »
You can even get crystals in polymer packages as well, instead of the more usual metal can. The main advantage is cost.
Software by day, hardware by night; blueAcro.com
« Reply #4 on: June 16, 2014, 01:10:08 pm »
What do you guys think about longevity.  The metal can they've been doing for decades, do you think it is tougher and has a longer mtbf vs the smd style ones?
Offline SirNick
« Reply #5 on: June 17, 2014, 08:52:23 pm »
I was wondering the same thing recently, since I started looking for SMD equivalents to all the PTH stuff I keep in personal inventory.  Then I started noticing SMD crystals everywhere.  I guess I just didn't notice before because I didn't know what I was looking for.
For e.g., I have a stack of Juniper hardware behind me... router chassisesses, interface cards, routing engine cards, you name it.  There are a ton of SMD crystals on those.
If it's good enough for production telco equipment, it's good enough for me, and probably for you.  I say: Match the part specs to the requirements as usual and sail on.
Offline dannyf
« Reply #6 on: June 17, 2014, 09:11:17 pm »
I have used both and I don't think there is much difference. The metal can allows you to ground it to minimize emi.
