Author Topic: Ferrite inductor or Coil Inductor for Boost Converter  (Read 2891 times)
Offline SwissEngineerTopic starter
« on: February 04, 2016, 09:48:11 am »
Hello Everyone,
I am designing a board and I need to choose the right inductor for my boost converter (TPS61220). The Vin is 3,6V and Vout 5,2V.
But my question is: Can I use a Ferrite bead as an inductor (http://www.digikey.ch/product-detail/fr/MLZ1608N4R7LTD25/445-17071-1-ND/4869871), I can't see the difference between a 4,7uH ferrite and a 4,7uH coil...
Thanks for the help
Nothing is complicated, you just need more time.
Offline krivx
  • Country: ie
Re: Ferrite inductor or Coil Inductor for Boost Converter
« Reply #1 on: February 04, 2016, 09:57:43 am »
How much current are you looking for? It looks like that ferrite will saturate at only 80mA.
« Reply #2 on: February 04, 2016, 10:09:44 am »
True... But why is the saturation current lower than the nominal? I wanted the maximum of the boost, so 400mA.
Offline RobK_NL
« Reply #3 on: February 04, 2016, 10:21:55 am »
Well, I would suggest to look at the graph for "INDUCTANCE VS. DC BIAS" for that ferrite and then compare it to the graph for this coil:
http://www.digikey.ch/product-detail/fr/CIG22B4R7MNE/1276-6218-1-ND/3972136
Still don't see it?  ;)
Tell us what problem you want to solve, not what solution you're having problems with
« Reply #4 on: February 04, 2016, 10:26:30 am »
Okay just found the awnser. :)
A Ferrite will decrease the inductance as the current increases, so when the current is nominal, the inductance is null.
On the opposite, the Coil will keep the inductance until the saturation current. (See pictures below)
Conclusion (correct me if I'm wrong) : I can't use a ferrite instead of a coil with a boost converter
PS : I saw the graph before your reply  :D but thanks!!
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: February 05, 2016, 02:57:08 am »
Ferrite beads are sold by small-signal impedance at some frequency, at zero DC.  (I'm amazed those TDK parts are even sold by inductance!)
They are not intended to function under DC bias (despite their typically generous current ratings, and frequent use in power supply rails).
Inductors are sold by inductance and DC bias.  (Conversely, they don't usually specify impedance at frequency, which makes it difficult to estimate efficiency.)
Inductors are made to store energy, ferrite beads are made to crudely filter (or dampen) small signal pins.
Shop accordingly :-+
Seven Transistor Labs, LLC
