Author Topic: Progamable dso v cro  (Read 600 times)
Offline m3vuvTopic starter
« on: August 31, 2020, 03:12:16 pm »
hi all,ive a kenwood DCS-8200,also a tek 453 scopes,both 50mhz,just wondered wha the differences are to use these,sort of a comparison,any ideas,i havent a clue,cheers in advance,m3vuv
« Last Edit: August 31, 2020, 04:04:55 pm by m3vuv »
Offline Gyro
Re: Progamable dso v cro
« Reply #1 on: August 31, 2020, 07:22:49 pm »
If you have both of them, can't you tell?  :-//
Best Regards, Chris
Offline Pawelr98
« Reply #2 on: September 01, 2020, 01:05:25 am »
453 is an older scope, still using tube rectifiers for HV.
The rest is transistors. Doesn't even use integrated circuits.
Some early versions used Nuvistor tubes as well.
Kenwood is a far more modern thing.
Has an ADC, can store data and display it on the screen as well as performing many other things.
But otherwise it also works as a normal analog scope.
The manual is on the first page in google if you search for this model.
