Author Topic: Wide range discrete negative voltage regulator  (Read 939 times)
Offline SK_Caterpilar_SKTopic starter
  • Country: sk
« on: August 31, 2020, 08:56:20 pm »
So I have been going arround the internet trying to find a negative voltage regulator but all that pops up is the 79xx stuff. I cant really fund a universal schematic I could use to achieve what I want. So here are the speciiffications I would like to achieve
Input voltage -130V
Output voltage : Variable between -20 and -100
Output current would be a few mA (10mA)
The purpose of this regulator is providing bias voltage for a vacuum tube amplifier.
If anyone can point me a to universal circuit I could modify to fit my needs then I would be gratefull for that too.
Many thanks :)
  • Country: sk
Re: Wide range discrete negative voltage regulator
« Reply #2 on: August 31, 2020, 09:47:18 pm »
https://www.eleccircuit.com/the-variable-high-voltage-power-supply-0-300v/
Positive voltage regulator : not what I need
https://sound-au.com/project151.htm
still a positive voltage regulator
https://www.homemade-circuits.com/0-300v-variable-voltage-current/
yet another positive voltage regulator
https://tubecad.com/2006/11/blog0087.htm
did you guess it? its a positive voltage regulator once again
I need a negative voltage regulator..one that can be scaled up. None of these are really any help to me
Offline aargee
« Reply #3 on: August 31, 2020, 10:21:39 pm »
Not that I've looked for what you want, but is there any reason you can't use an isolated supply using one of the positive power supply circuits and reference positive to common/ground?
Not easy, not hard, just need to be incentivised.
  • Country: sk
« Reply #4 on: August 31, 2020, 11:05:13 pm »
Yes, its the way the power transformer is designed. its a 800VAC CT. On one side of the CT I have a 100VAC tap
Online MasterT
« Reply #5 on: August 31, 2020, 11:28:34 pm »
Changing polarity is simple, N-MOSFET & NPN BJT replace with P-MOSFET and PNP BJT.  Turn over Zenner .
