Are you using good parts from known reputable suppliers? Random cheap parts can be counterfeit or way off from the published specs. Is there conductive flux or other contamination on the PCB? You might try removing parts and checking the current, find out if it's something like a voltage regulator, leaky capacitor or the microcontroller causing the current draw.
