Ebay is rife with 3 terminal voltmeters that can read voltages which are higher than the negative terminal of the voltmeter and they work well for the price.
Here is my problem : I have a +3.3V supply and a -2.5V supply with a common ground which are derived from +9V and -9V respectively using voltage regulator IC's and would like to monitor these supplies using these Ebay displays.
I have connected the +3.3V supply to the sense terminal of the aforesaid 3 terminal voltmeter with the Vcc of the display being connected to 9V from where the 3.3V is derived and all's well.
To monitor the -2.5V rail, when I connect the -2.5V to a second voltmeter sense terminal , it shows zero as it cannot seem to read voltages that are are lower than its negative terminal.
I tried connecting the -9V and ground terminals to the negative and positive terminals of the display but then when I connect the sense terminal to the -2.5V , it reads 6.5V as it should.
Are there cheap LED meters (below $5) that can indeed read negative voltages as well? What other alternates do I have that can fix this issue?
