Author Topic: Integrating ASK 433MHz module into the PCB  (Read 1276 times)
Offline ali_asadzadehTopic starter
« on: June 24, 2017, 09:14:29 am »
We know that these modules are dirt cheap, but for compactness, I want to integrate the whole module into the main PCB, do  we have a schematic for them? what about the single chip solution versions? also can we integrate the PCB antenna, say a 17CM trace that wraps around itself,
Some modules like Lr45b seems to use a very simple circuit ,what about the transmitter, do we have a similar case?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline stj
Re: Integrating ASK 433MHz module into the PCB
« Reply #1 on: June 24, 2017, 11:30:58 am »
just design your pcb with a cutout to fit a module into  :D
