Motor is being used in an old front loader washing machine with pulley-belt motor to drum drive. The washer now serves well as a semi-precious stone polisher.
Its a slow grind.
Motor is 2-Amp type, and is phase-controlled. Always using phase-control, with kickstart code, and once the tub is started up, uses PID speed control by my code.
Yes, I have (salvaged from ATX P/S) yellow plastic rectangular X-type caps (.1uF to 2uF all labeled at 250VAC, label shows possibly every safety spec abbrev. possible)for use to make a snubber
Since things are back to normal, I think the EMI was radiating not from the motor case, but from fast dI/dt dV/dt and the length of the motor wiring, which is about 3-ft from my controller to the motor. With the CMC, the leads from the choke to the brushes is now less than 2-in and the inductance of the CMC makes the (previous to adding choke) sharp rise/fall times to be very much longer..
I picked 22-ohm as a possible snubber min value to safely limit the cap peak current to < ~12-amps at 240VAC, but higher values of resistance may greatly decrease EMI suppression. I am not using the snuuber yet because I am not sure if the peak voltages developed across the brush contacts may be too high and would cause these 250VAC caps to fail. Besides, as Bubba would say, its working now.
