I'm building a device that will be housed in a plastic, 50x50x10cm waterproof briefcase and will be placed outside my house, in the countryside. Basically it's a radio datalogger that will monitor the temperature and the moisture level and send me the information thru 433MHz packets.
The climate sensors will be external, connected thru a waterproof connector.
I'm using a linear regulator for the 5V rail, and the total power drain by the ciruitry is 1,4W.
With a so low efficency device (about 35%), there is 0,9W to heat to dissipate (a lot of wasted energy), so I must have an external heatsink, otherwise with moderate or even warm climates, the heat will grow inside the briefcase and possibly will blow up the circuitry . The waterproof sealing don't allow any air flow inside.
I will do some tests in the next days using a DC-DC converter with an efficency of 78% instead the linear regulator, having so "only" 0,3W of heat to dissipate, but I'd like to have a couple of advices from you:
are 0,3W of heat, something that I can ignore since the poor thermal insulation of the briefcase will equalize any difference?
I mean, in summer time the direct sunlight would raise quickly the internal temperature up to 60°C, and I guess that 0,3W of internal heat could be ininfluent for the circuitry (while 0,9W is too much).
What do you think about it?
