Do you have a higher power supply voltage available? If you can bump the supply voltage to the CD4051 up to 4.5V, the resistance will drop. I wouldn't recommend going any higher, otherwise it won't work properly, with 3.3V logic. If you have a 5V supply, use a diode and a pull-down resistor to create 4.4V.
