Hi!
As a small project I've decided to undertake during my break, I'm working on creating a very high input impedance, 8-channel differential DAQ to work on monitoring neural cells and their impulses (a group I'm associated with is trying to get them to create basic digital logic circuits). As such, I've been trying to figure out how to create as light of a load as possible on the cells, because I don't know how many will be in each "node", and I need some advice. My aim is for the DAQ to draw sub-picoamps as well as having sub-picofarad input capacitance.
My current plan is to incorporate an AD8639 op-amp as the front-end buffer in a follower configuration, or a instrumentation amplifier configuration, given +/- 5V supplies. Based on the datasheets, it should be doing only about ~100-500 fA at room temperature. I would have a trace from the negative input of each op-amp acting as a shield for the non-inverting input, going back to the pin of the input cable connector.
However, it does appear to have several picofarads of input capacitance, which seems like a no-go when the cells can only contain so much individual charge, even though the resulting rise-times are more than acceptable (the bandwidth is about 1 kilohertz tops). Is this reasonable to think it may be a problem?
I've been looking into bootstrapping the supplies using BJT current mirrors, and then using another op-amp to buffer the shield and supplies to reduce the capacitance. Does anyone think this is overkill?
Full schematics and board design to follow.
