Bloch: thanks for your continious help. I have read the USB standard for USB 2.0.
I know Ohms law, but to really understand it I guess will take me alot of time and practice in different scenarios. I guess in my case trying the resistor, I knew that I would get a voltage drop. I guess I should see the mobile phone as just another resistor adding it together with my 470R resistor. If the mobile phone has a resistance of 2280R I guess 20% of the voltage would be over my 470R resistor and the rest 80% would be over the mobile phone. Then I would also guess that the resistance of the mobile phone might be different depending on how much it is charged. Or am I thinking in the wrong direction here?
Fcb: It is an Android phone. My aim is not to charge the phone. I just want to provide a steady 5 volt low current to it. But maybe this is not possible? Maybe it will be unstable if the phone is exhausting it?
Bloch & Gakex: Yes I used them in series, they were almost depleted and together thy were very close to 5.0 volt. I used them for many days, the phone would not charge very much. there was even a message on the phone "Very low current, not charging" or something. But then again, that is what I want to accomplish. I dont want to charge the phone, I want to give it a very low current stable 5 volt reference so that it will start communicating. Unfortunately it needs the 5V to sense that there is something connected in the other end. Preferably I would cut the red wire of the USB cable, but that wont work.
But maybe my setup with the TI REG710-5V is completely wrong for this?
KedasProbe: I also thought about something like this, however I am not sure how to do it. I am using the FTDI VNC2 microprocessor for USB communication. I will dig into the documentation and see if there is something I can configure.
Thank you all for your help and patience with me
