Author Topic: Frequency Response  (Read 3042 times)
Offline Nick_KimiTopic starter
Frequency Response
« on: January 06, 2016, 03:07:10 pm »
Hi there,
I would like to measure the frequency response of a radio frequency current transformer (as attached) using DSA815 1.5 GHz Spectrum Analyzer. How can I do that? I try a few times, and this is what I got (as attached) and I don't think it represent the frequency response of the sensor.
Many apologies for any inconvenience caused.
Offline awallin
Re: Frequency Response
« Reply #1 on: January 06, 2016, 03:41:04 pm »
Do you have a model number for the sensor and a datasheet?
Post a schematic of your measurement setup. What are you measuring and how?
« Reply #2 on: January 06, 2016, 04:01:33 pm »
Hi Awallin,
Thanks for replying my post.
Yes, I do have the model number for the sensor and a datasheet, all the information of the sensor are there. However, the sensor's performance will decrease by time. That is why I want to measure the frequency response of the sensor again. I need to have it in order to validate my results.
I want to measure the frequency response of the sensor. I should have something as attached no.1. I followed one of the EEVblog video ( ) but I did not get it.
As attached no. 2 is my schematic of the measurement. And I'm not really sure the measurement setup is correct or not.
cheers.
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #3 on: January 06, 2016, 04:09:56 pm »
It is not correct. To measure the response of a current sensor you need at the very least to make reasonably flat the source current frequency response. To do it you have to use a matched load and a coaxial feed. For starters you can use a 50 Ohm coaxial cable from the generator's output with a 50 (47 or 51) Ohm metal film resistor at the end of it, placed in the transformer opening. It would not be a very accurate method but miles better than what you've tried.
Cheers
Alex
Offline babysitter
  • pushing silicon at work
« Reply #4 on: January 06, 2016, 04:29:35 pm »
Mr. Smith describes a lot of suitable DIY probes and talks about ther characteristics, one of the simplest:
http://emcesd.com/tt080699.htm
babysitter
I'm not a feature, I'm a bug! ARC DG3HDA
« Reply #5 on: January 06, 2016, 05:34:31 pm »
Hi Alex,
Oh yeah, it's make sense. As attached is the measurement schematic, is that what you mean right? And then I need to make sure that I use a correct value of resistor, right?
cheers.
