Hello!
I am redesigning a circuit that was originally used to cycle the glow plugs on a diesel motor.
But I've ran into a bit of a hiccup
There is an SIP-7 Resistor Network that appears to be custom, I was wondering if anyone has any more information on where I could get something like it!
The dimensions of the network are:
18mm W x 7mm H (without pins) x 1.3mm D
I need to find a suitable replacement for it, the pins are evenly spaced 2.5mm apart from each other.
I've done testing on it and have included a crude schematic below:
The measurements were performed out of the original circuit!
Any information about how I can go about getting something as a suitable replacement would help!
