Um, right. You did say that you were using a PVM monitor.Why don't you use normal BNC cables for the output at least.Why not sync-on-green?Are you planing on looping through the composite input to the sync input for the RGB?You really wouldn't rather just retrofit whatever is composite to RGB?
Why don't you move that inline coneector closer in or on the top.Every square inch of PCB you save is money.I don't mean for you to move the backplane connectors closer, but there is a bunch of trimming that you can do.I built a 4 in/4out matrix once.Since the matrix itself was a bunch of work the first controller I had was 4 BCD thumbwheel switches.Later I build a controller that worked off an existing control bus.It didn't even require a µC, just some latches and stuff.Well, what kind of control do you need? Network? IR? Pushbutton?An OLED display would look nice.Anything on the AVR8-STM-RPi continuum would do the job.Most people would just grab what they know best.
So now it's 12 inputs?Why so much control wiring coming in?Don't you just need 4 bits going to a 1 of 16 demux?Unless you want to split to select the A & V separately.Some might use an I²C latch or use SPI to reduce line count but 4 is already pretty low.
#include <Arduino.h>#include <U8g2lib.h>#include <EEPROM.h>#include <Wire.h>#define CLK 2#define DT 3byte currentStateCLK;byte lastStateCLK;byte input = EEPROM.read(0);byte currentinput = 0;byte dplayedinput = 1;unsigned long lastdisplaychange = 0;unsigned long currenttime = 0;unsigned long encodewait = 0;const byte demuxout[] PROGMEM = {B00100000,B00000000,B00100000,B00000000,B00100000,B00000000,B00100000,B00000000,B00100000,B00000000,B00100000,B00100000,B00000000,B00100000,B00000000,};const byte x1[] PROGMEM = {13,16,20,3,33,34,32,25,8,35,42,5,15,38,14};const char console_1[] PROGMEM = "Playstation";const char console_2[] PROGMEM = "Gamecube";const char console_3[] PROGMEM = "Laserdisc";const char console_4[] PROGMEM = "Playstation 2";const char console_5[] PROGMEM = "Saturn";const char console_6[] PROGMEM = "Xbox";const char console_7[] PROGMEM = "SNES";const char console_8[] PROGMEM = "Genesis";const char console_9[] PROGMEM = "Master System";const char console_10[] PROGMEM = "VCR";const char console_11[] PROGMEM = "PC";const char console_12[] PROGMEM = "Casio Loopy";const char console_13[] PROGMEM = "PC Engine";const char console_14[] PROGMEM = "NES";const char console_15[] PROGMEM = "Super Nova";PGM_P const console[] PROGMEM = {console_1,console_2,console_3,console_4,console_5,console_6,console_7,console_8,console_9,console_10,console_11,console_12,console_13,console_14,console_15};const char tvset_1[] PROGMEM = "AUX RGB 0";const char tvset_2[] PROGMEM = "Y/C 1";const char tvset_3[] PROGMEM = "Video A 2";const char tvset_4[] PROGMEM = "AUX RGB 3";const char tvset_5[] PROGMEM = "AUX RGB 4";const char tvset_6[] PROGMEM = "AUX RGB 5";const char tvset_7[] PROGMEM = "AUX RGB 6";const char tvset_8[] PROGMEM = "AUX RGB 7";const char tvset_9[] PROGMEM = "AUX RGB 8";const char tvset_10[] PROGMEM = "Video B 9";const char tvset_11[] PROGMEM = "Video B 10";const char tvset_12[] PROGMEM = "Video B 11";const char tvset_13[] PROGMEM = "Video B 12";const char tvset_14[] PROGMEM = "Video B 13";const char tvset_15[] PROGMEM = "AUX RGB System";PGM_P const tvset[] PROGMEM = {tvset_1,tvset_2,tvset_3,tvset_4,tvset_5,tvset_6,tvset_7,tvset_8,tvset_9,tvset_10,tvset_11,tvset_12,tvset_13,tvset_14,tvset_15};const char switchb_1[] PROGMEM = "";const char switchb_2[] PROGMEM = "Switcher 2 Input 1";const char switchb_3[] PROGMEM = "";const char switchb_4[] PROGMEM = "";const char switchb_5[] PROGMEM = "";const char switchb_6[] PROGMEM = "";const char switchb_7[] PROGMEM = "";const char switchb_8[] PROGMEM = "";const char switchb_9[] PROGMEM = "";const char switchb_10[] PROGMEM = "Switcher 2 Input 2";const char switchb_11[] PROGMEM = "Switcher 2 Input 3";const char switchb_12[] PROGMEM = "Switcher 2 Input 4";const char switchb_13[] PROGMEM = "Switcher 2 Input 5";const char switchb_14[] PROGMEM = "Switcher 2 Input 6";const char switchb_15[] PROGMEM = "Kaneko";PGM_P const switchb[] PROGMEM = {switchb_1,switchb_2,switchb_3,switchb_4,switchb_5,switchb_6,switchb_7,switchb_8,switchb_9,switchb_10,switchb_11,switchb_12,switchb_13,switchb_14,switchb_15};U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);void setup(void) { u8g2.begin(); if (input < 0 || input > 14){ input = 0; } //Serial.begin(9600); DDRB = B00111111; DDRD = B00000010; //pinMode(CLK,INPUT); //pinMode(DT,INPUT); lastStateCLK = digitalRead(CLK); attachInterrupt(0, Encoderchange, CHANGE); attachInterrupt(1, Encoderchange, CHANGE); //bootscreen(); displayinput(); setinput();}void loop(void) { currenttime = millis(); if (dplayedinput != input){ displayinput();} if (input != currentinput && currenttime > lastdisplaychange){ setinput();} if (currenttime + 1001 - lastdisplaychange > 10000){ u8g2.clearBuffer(); u8g2.sendBuffer(); } //input++; //Repeat all inputs //delay(1000); }void displayinput(){ u8g2.clearBuffer(); if (input == 8) { u8g2.setFont(u8g2_font_crox4t_tf); } else if (input == 14) { u8g2.setFont(u8g2_font_helvB12_tf); } else{ u8g2.setFont(u8g2_font_crox5t_tf); } byte buffer6 pgm_read_byte(&x1[input]); char buffer1[strlen_P(console[input])]; strcpy_P(buffer1, (PGM_P)pgm_read_word(&console[input])); u8g2.drawStr(buffer6,38,buffer1); u8g2.setFont(u8g2_font_t0_12_mr); char buffer2[strlen_P(tvset[input])]; strcpy_P(buffer2, (PGM_P)pgm_read_word(&tvset[input])); u8g2.drawStr(7,55,buffer2); u8g2.setFont(u8g2_font_t0_12_mr); char buffer3[strlen_P(switchb[input])]; strcpy_P(buffer3, (PGM_P)pgm_read_word(&switchb[input])); u8g2.drawStr(7,15,buffer3); //Serial.println(input); u8g2.sendBuffer(); lastdisplaychange = currenttime + 1000; dplayedinput = input; }void Encoderchange(){ currenttime = millis(); currentStateCLK = digitalRead(CLK); if (currentStateCLK != lastStateCLK && currentStateCLK == 1 && currenttime >= encodewait){ if (digitalRead(DT) != currentStateCLK) {if (input > 0) {input --;} else {input = 14;}} else {if (input < 14) {input ++;} else {input = 0;}} encodewait = currenttime + 350; } lastStateCLK = currentStateCLK;}void setinput(){ byte buffer5 pgm_read_byte(&demuxout[input]); PORTB = buffer5; EEPROM.write(0, input); u8g2.drawFrame(0,0,128,64); u8g2.sendBuffer(); currentinput = input; }//void bootscreen(){ //u8g2.setFont(u8g2_font_t0_12_mr); //u8g2.drawStr(15,20,"Custom Video"); //u8g2.drawStr(25,35,"Switch"); //u8g2.drawStr(50,55,"V.75b"); //u8g2.sendBuffer(); //delay(3000); //}
You've got 200 lines of code... and a big u8g2 library which takes 1024 bytes just for the frame buffer.(That is a 64 x 128 OLED?)Try commenting out all the u8g2 stuff just to see how big that builds.Sure, you could go to a bigger processor.If you keep your text aligned with the eight 8 bit "stripes" you don't need a frame buffer.Probably your smallest text would be 16 pixels high.You could make the big stuff 24 or 32 pixels high.Of course you'd have to rewrite your display library.That's interesting the IXYS optoisolator.The form factor, pinout is as a replacement for those SIP reed relays.Even the fact that they put a resistor in.
#include <Arduino.h>//#include <U8g2lib.h>#include <EEPROM.h>#include <Wire.h>#define CLK 2#define DT 3byte currentStateCLK;byte lastStateCLK;byte input = EEPROM.read(0);byte currentinput = 0;byte dplayedinput = 1;unsigned long lastdisplaychange = 0;unsigned long currenttime = 0;unsigned long encodewait = 0;const byte demuxout[] PROGMEM = {B00100000,B00000000,B00100000,B00000000,B00100000,B00000000,B00100000,B00000000,B00100000,B00000000,B00100000,B00100000,B00000000,B00100000,B00000000,};const byte x1[] PROGMEM = {13,16,20,3,33,34,32,25,8,35,42,5,15,38,14};const char console_1[] PROGMEM = "Playstation";const char console_2[] PROGMEM = "Gamecube";const char console_3[] PROGMEM = "Laserdisc";const char console_4[] PROGMEM = "Playstation 2";const char console_5[] PROGMEM = "Saturn";const char console_6[] PROGMEM = "Xbox";const char console_7[] PROGMEM = "SNES";const char console_8[] PROGMEM = "Genesis";const char console_9[] PROGMEM = "Master System";const char console_10[] PROGMEM = "VCR";const char console_11[] PROGMEM = "PC";const char console_12[] PROGMEM = "Casio Loopy";const char console_13[] PROGMEM = "PC Engine";const char console_14[] PROGMEM = "NES";const char console_15[] PROGMEM = "Super Nova";PGM_P const console[] PROGMEM = {console_1,console_2,console_3,console_4,console_5,console_6,console_7,console_8,console_9,console_10,console_11,console_12,console_13,console_14,console_15};const char tvset_1[] PROGMEM = "AUX RGB 0";const char tvset_2[] PROGMEM = "Y/C 1";const char tvset_3[] PROGMEM = "Video A 2";const char tvset_4[] PROGMEM = "AUX RGB 3";const char tvset_5[] PROGMEM = "AUX RGB 4";const char tvset_6[] PROGMEM = "AUX RGB 5";const char tvset_7[] PROGMEM = "AUX RGB 6";const char tvset_8[] PROGMEM = "AUX RGB 7";const char tvset_9[] PROGMEM = "AUX RGB 8";const char tvset_10[] PROGMEM = "Video B 9";const char tvset_11[] PROGMEM = "Video B 10";const char tvset_12[] PROGMEM = "Video B 11";const char tvset_13[] PROGMEM = "Video B 12";const char tvset_14[] PROGMEM = "Video B 13";const char tvset_15[] PROGMEM = "AUX RGB System";PGM_P const tvset[] PROGMEM = {tvset_1,tvset_2,tvset_3,tvset_4,tvset_5,tvset_6,tvset_7,tvset_8,tvset_9,tvset_10,tvset_11,tvset_12,tvset_13,tvset_14,tvset_15};const char switchb_1[] PROGMEM = "";const char switchb_2[] PROGMEM = "Switcher 2 Input 1";const char switchb_3[] PROGMEM = "";const char switchb_4[] PROGMEM = "";const char switchb_5[] PROGMEM = "";const char switchb_6[] PROGMEM = "";const char switchb_7[] PROGMEM = "";const char switchb_8[] PROGMEM = "";const char switchb_9[] PROGMEM = "";const char switchb_10[] PROGMEM = "Switcher 2 Input 2";const char switchb_11[] PROGMEM = "Switcher 2 Input 3";const char switchb_12[] PROGMEM = "Switcher 2 Input 4";const char switchb_13[] PROGMEM = "Switcher 2 Input 5";const char switchb_14[] PROGMEM = "Switcher 2 Input 6";const char switchb_15[] PROGMEM = "Kaneko";PGM_P const switchb[] PROGMEM = {switchb_1,switchb_2,switchb_3,switchb_4,switchb_5,switchb_6,switchb_7,switchb_8,switchb_9,switchb_10,switchb_11,switchb_12,switchb_13,switchb_14,switchb_15};//U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);void setup(void) { //u8g2.begin(); if (input < 0 || input > 14){ input = 0; } //Serial.begin(9600); DDRB = B00111111; DDRD = B00000010; //pinMode(CLK,INPUT); //pinMode(DT,INPUT); lastStateCLK = digitalRead(CLK); attachInterrupt(0, Encoderchange, CHANGE); attachInterrupt(1, Encoderchange, CHANGE); //bootscreen(); displayinput(); setinput();}void loop(void) { currenttime = millis(); if (dplayedinput != input){ displayinput();} if (input != currentinput && currenttime > lastdisplaychange){ setinput();} if (currenttime + 1001 - lastdisplaychange > 10000){ //u8g2.clearBuffer(); //u8g2.sendBuffer(); } //input++; //Repeat all inputs //delay(1000); }void displayinput(){ //u8g2.clearBuffer(); if (input == 8) { //u8g2.setFont(u8g2_font_crox4t_tf); } else if (input == 14) { //u8g2.setFont(u8g2_font_helvB12_tf); } else{ //u8g2.setFont(u8g2_font_crox5t_tf); } byte buffer6 pgm_read_byte(&x1[input]); char buffer1[strlen_P(console[input])]; strcpy_P(buffer1, (PGM_P)pgm_read_word(&console[input])); //u8g2.drawStr(buffer6,38,buffer1); //u8g2.setFont(u8g2_font_t0_12_mr); char buffer2[strlen_P(tvset[input])]; strcpy_P(buffer2, (PGM_P)pgm_read_word(&tvset[input])); //u8g2.drawStr(7,55,buffer2); //u8g2.setFont(u8g2_font_t0_12_mr); char buffer3[strlen_P(switchb[input])]; strcpy_P(buffer3, (PGM_P)pgm_read_word(&switchb[input])); //u8g2.drawStr(7,15,buffer3); //Serial.println(input); //u8g2.sendBuffer(); lastdisplaychange = currenttime + 1000; dplayedinput = input; }void Encoderchange(){ currenttime = millis(); currentStateCLK = digitalRead(CLK); if (currentStateCLK != lastStateCLK && currentStateCLK == 1 && currenttime >= encodewait){ if (digitalRead(DT) != currentStateCLK) {if (input > 0) {input --;} else {input = 14;}} else {if (input < 14) {input ++;} else {input = 0;}} encodewait = currenttime + 350; } lastStateCLK = currentStateCLK;}void setinput(){ byte buffer5 pgm_read_byte(&demuxout[input]); PORTB = buffer5; EEPROM.write(0, input); //u8g2.drawFrame(0,0,128,64); //u8g2.sendBuffer(); currentinput = input; }//void bootscreen(){ //u8g2.setFont(u8g2_font_t0_12_mr); //u8g2.drawStr(15,20,"Custom Video"); //u8g2.drawStr(25,35,"Switch"); //u8g2.drawStr(50,55,"V.75b"); //u8g2.sendBuffer(); //delay(3000); //}
Will be far cheaper than your build.
https://www.amazon.co.uk/Component-Switch-Splitter-Selector-Converter/dp/B01M4LOU12Will be far chepaer than your build.
Looking good.Are you using the knob pushbutton for "take"?I'd think that switching on knob rotation itself would be kind of distracting.
