Author Topic: [Solved] Help identify this component  (Read 788 times)
Offline spilihpsTopic starter
« on: March 17, 2018, 04:37:58 pm »
Hello!
This: https://ibb.co/gcQsvH
Trying to figure out what this component is.
The only thing i know is that pin 1 is connected via a resistor to the gate of a mosfet.
Any ideas? Not sure if it should be read as B 11, or if the lines are not "1"?
« Last Edit: March 18, 2018, 06:34:25 pm by spilihps »
Offline MattHollands
    • Matt's Projects
Re: Help identify this component
« Reply #1 on: March 17, 2018, 06:17:23 pm »
http://www.s-manuals.com/smd/b1
Looks most likely to be a PNP transistor.
Read about my stuff at: projects.matthollands.com
« Reply #2 on: March 18, 2018, 06:34:06 pm »
Thank you very much. Seems to be the right one.
In all luck, However, it was not the fault.
