Interesting ideas, i thought dimmers where not usable for inductive loads. Not the resistive types anyway. if i could have changed the wave form in the primarys (with out over heating the windings) I would have used a dimmer on the single primary winding. I have finished the pair of transformers in series, both primary and secondarys. I'm getting 20.70 Volts AC with no load, and 17.60 Volts with 200 watts of halogen lamp load, 4 x 50 watt lamps. The cable i used is advertised as being capable of currents up to 30 Amps at 12.00 Volts. I don't know it could handle that much current, but at 200 watts, i'm almost certain it can handle a bit more current. i'd say 18 Amps to 20 Amps with a 50% duty cycle wouldn't be unreasonable, although i'd expect to drop a bit more voltage form the secondary input due to the lower series primary input. But its looking good so far. I didn't do the stat's for a 200 x 100 x 20 mm piece of aluminium plate as a heatsink for 4 x TIP36C transistors. And the rectifier, i wasn't happy with the aluminium it was bolted to with the transformer chassis assembly. Hopefully with air flow it will keep things cool.
