Author Topic: DAC  (Read 659 times)
Offline ranganatennakoonTopic starter
  • Country: lk
DAC
« on: April 29, 2020, 04:26:07 pm »
can we make DAC sine wave inverter?
i think, if we can use DAC for making sine wave inverter it is batter than spwm :-BROKE
Offline coromonadalix
Re: DAC
« Reply #1 on: April 29, 2020, 05:12:18 pm »
For a pure sine wave ???    low thd, low jitter,  precision ?  up to witch frequency ?
You can make sine wave by other means too ?
A cheap way of doing it :
http://www.learningaboutelectronics.com/Articles/Sine-wave-generator-circuit-with-a-555-timer.php
You can make it with some mcu with added filtering
The list goes on and on
« Last Edit: April 29, 2020, 05:14:01 pm by coromonadalix »
Offline Prehistoricman
Re: DAC
« Reply #2 on: April 30, 2020, 12:17:14 am »
SPWM is essentially a class D amplifier. High efficiency. Most DACs (thinking of audio output ICs) would use less efficient class A output drivers.
Which is better completely depends on the application.
Offline David Hess
  • DavidH
Re: DAC
« Reply #3 on: April 30, 2020, 03:48:48 am »
You can but efficiency is limited to about 66% because of the linear output stage.  A class-D amplifier can be 95% efficient or better.
