Hello everyone,
Do you have any suggestions for tiny (3mm max width) 3-4 pin connectors and cables, where the cables are readily available in the market (cheaply) in around 25-50cm lenghts?
If I needed 2 pins I would use u.fl connectors, but I need at least 3!
