Author Topic: Replacing wire ceramic resistors with equivalents  (Read 1794 times)
Offline nunoTopic starter
  • Country: pt
« on: March 08, 2018, 03:27:45 am »
Do you see a problem replacing a typical wire ceramic 5W resistor (those white blocks) by an equivalent series of 2 carbon (3W) ones? (assuming no problem with voltage & current withstanding)
« Last Edit: March 08, 2018, 03:32:45 am by nuno »
Offline Ian.M
Re: Replacing wire ceramic resistors with equivalents
« Reply #1 on: March 08, 2018, 03:52:52 am »
Carbon composition resistors dissipating significant power can 'cook' the binder and decrease in resistance till they overheat and burn up, and when they do so, can do significant damage to the board and surrounding parts.   It will do for testing, but I wouldn't let it out of the shop like that.   Non-flammable metal film resistors would be more acceptable but have a lower pulse overload capability than wirewounds.
The following users thanked this post: nuno
Offline Nusa
« Reply #2 on: March 08, 2018, 06:58:12 am »
Generally speaking, replacing a 5W part with a lower-rated 3W part is not a good idea. If the previous part failed from heat, its a REALLY BAD idea.
Now if the replacement resisters were 3W appropriate values in parallel (making it a 6W replacement), you might be ok.
  • Country: pt
« Reply #3 on: March 08, 2018, 11:23:42 am »
So that's the same as saying a 3W *carbon* resistor isn't really up to its spec, or it's the failure mode that worries you? I would be increasing the total wattage from 5W to 6W, since the original 5W resistor burnt (actually, 2 of them burnt, and they were in series with nothing else in between, which I find rather odd but I don't see any other problem on the board and it works).
The main reason for the swap is actually that I can't get the original resistors in time and budget, but it wouldn't hurt to increase wattage a little too.
I don't see a difference using a series or parallel configuration, the idea was to use 2 x 3W resistors in series, so that's 6W, each resistor with half the value of the original one, of course.
« Last Edit: March 08, 2018, 11:30:45 am by nuno »
Offline mikerj
« Reply #4 on: March 08, 2018, 12:00:09 pm »
Series or parallel makes no difference, the power dissipation is shared between the resistors in either case.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: March 08, 2018, 12:03:23 pm »
Carbon what, carbon film? Carbon comp?
Don't recall seeing either in 3W sizes, new (not that I go out of my way to look for comp, mind), parts in that range are usually metal-oxide or the like.
But anyway, as long as ratings are met, no problem.
Seven Transistor Labs, LLC
  • Country: pt
« Reply #6 on: March 08, 2018, 12:11:13 pm »
I don't have a datasheet, the description just says "carbon". 250V max.
Offline Benta
« Reply #7 on: March 08, 2018, 12:47:33 pm »
Depends on the application. Wirewound resistors are very resilient to current pulse overloads. Carbon types don't like that kind of abuse.
Offline Nusa
« Reply #8 on: March 08, 2018, 12:51:23 pm »
Oops, I apparently got my rules of thumb confused. Now that I've checked myself with the math, you guys are right, 6W either way. Apologies.
