Make a neon lamp blinker. A neon with a few kiloohms in series, paralled with a capacitor of a hundred nanofarads or so. Ground one end, connect the other to your high voltage via a resistor of some hundred kiloohms, you'd find it starts blinking slowly at about 90V and faster as the voltage increases. Your high-value resistor needs to be able to take the full voltage so is probably best as a specialist high voltage resistor or as many normal ones in series.
