Author Topic: Datasheet unclear on absolute maximum ratings and active clamp voltage  (Read 2668 times)
Offline jeroen74Topic starter
At work we use a  IPS6044G which is a four channel intelligent protected high side switch. It also offers active clamping to demagnetise inductive loads quickly.
Now, I don't understand the following part: the datasheet states that the maximum output voltage is Vcc-35V. (In our application VCC=24V, so that equals to -11V). The specified clamping voltage is between 37 to 42V so during active clamping the voltage at Vout can be as low as 24-42 = -18V.  That's 7 volts more then is allowed  :-//
In an actual test I measured -15.8V which basically confirms the clamping voltage ~39V.
What use is this active clamp circuitry if it consistently violates the absolute maximum rating? Or am I misinterpreting the specification?
I asked IRF about it; their answer is that I should use another series as this one is not meant for 24V and they referred to appnote #1117 which is not really helpful on this particular issue.
I looked at other high side switches like from Infineon and ST and they don't mention an absolute maximum rating at all for the output, just a clamping voltage...
Offline Rufus
Re: Datasheet unclear on absolute maximum ratings and active clamp voltage
« Reply #1 on: October 07, 2013, 02:47:10 pm »
The abs min Vout and Voffset ratings are a little confusing but I think they mean the maximum voltage where the clamping mechanism will not turn on. Exceeding that voltage may activate the clamp and you then have current and power dissipation limits.
It is common to see specifications for input pin voltage of say VCC + 0.3v and an input pin maximum current of say 10mA while a voltage of greater than VCC + 0.3v would be required to get any pin current.
If you are actually using the clamps to absorb inductor stored energy be careful because they don't have much capability. That part has a plot of maximum load inductance against current and it is only 2mH at 3A for example.
« Reply #2 on: October 07, 2013, 07:10:13 pm »
Yes, I thought something like that too :) The active clamp controls the FET to get a controlled clamp voltage but this is only active when the driver turns off, not during other situations.
I really would like to IRF to state this a little more clearly in the datasheet. Let's see what their support department has to say on this, as I emailed them back that I'm still a little confused :)
The biggest inductive load we switch only draws a mere 24mA at 24V. That's not even in the graph, but extrapolating from it, the inductance must be a couple of Henries before it becomes a problem.
Offline dannyf
« Reply #3 on: October 07, 2013, 07:22:31 pm »
That doesn't make a whole lot of sense for the maximum output. Minimum output? Maybe.
« Reply #4 on: October 07, 2013, 07:30:35 pm »
Oh well.... yes....
Maximum output voltage: min= Vcc - 35V,  max=Vcc + 0.3V
