Author Topic: Altium - solder mask sliver  (Read 4917 times)
Offline treeTopic starter
« on: July 14, 2014, 04:44:52 pm »
Hello folks,
I would appreciate your help solving the following Altium problem. I want to be able to ignore the solder mask sliver violation for same net objects. For instance, I want the design rule checker to ignore the minimum solder mask sliver rule for a via and pad of the same net since they are already shorted and I don't care if the solder mask between them isn't present. However, I want the solder mask sliver rule to be violated when the objects are part of different nets. It would be nice if I could create a rule for this, but I'm having difficulties coming up with a custom query to do this. The other possibility would be to ignore specific violations, but I don't think Altium can do that.
Thanks.
Offline Rufus
Re: Altium - solder mask sliver
« Reply #1 on: July 14, 2014, 06:50:41 pm »
We have a specific Altium forum where this should have been posted.  Maybe a mod can move it.
Solder mask slivers are not a problem of lack of isolation. Thin slivers can not be manufactured so the board house will either remove them or reject your data.
« Reply #2 on: July 14, 2014, 06:54:24 pm »
I understand, but how do I get the software to recognize the slivers which are too thin only between different net objects and mark them, and only them, as violations.
Offline Precipice
« Reply #3 on: July 15, 2014, 08:27:38 am »
Is this not more easily spotted by setting up a pad-pad (different net) clearance rule? (as long as you're not doing weird things with soldermask pullback on a per-pad basis).
