Hello!
There are some 5V relays, 74HCTs, analog and 3,3V ATXMEGA processors (3,3V low drop regulator that uses the 5V as input), so the 5V should be regulated (+/-10%).
I've had a look at the TI converters but there are 2 problems: 1.) Only 2W, that might be not enough reserves, 2.) It looks like they only produce for very small input ranges (5V, 12V, 24V, all +/-10%). My input voltage will be in the range of 15-17V, so that would require a 12V preregulator too. A simple LM7812 will produce something between 1,5-2W heat when the full 3W of the converter are used. I'm looking for a solution that requires only external capacitors, maybe a small inductor and a polarity protection diode for the input.
In Austria any import not from countries within the European Union are only free up to 22€ (value of goods + shipping).
Between 22€ and 150€ we have to pay a import sales tax (normally 20%)
Over 150€ you have to pay import sales tax and customs duties.
